Help SMS Tone Problem :(
xOutlawx
Hello, I keep trying to change the tone for SMS notifications, but even though the one that I select is still selected, the tone "Lalande" plays instead. I tried turning it off and on, and it still only plays that tone. Has anyone found a solution to this? Thank you
I don't have it installed. I was going to get it though. Is that causing other problems on the Nexus?
No but there is an option in it to change the notification sound. I just thought if you had it installed that it might be the reason for your issue.
I found the problem. I originally went to Settings>Sound>Default Notification> then selected which tone I wanted. Now I went to the SMS app>Settings>Select Ringtone and that changed it. Thanks for the suggestion though. :D
