Root SnapChat Bug
bryan847
Anyone here use snapchat? I am running Steel Droid ICS and whenever I use the front camera on snapchat I just get a green screen. I was wondering if anyone else had the same problem on any other roms, or if it is just the rom.
I am have similar issues running gummy 1.3.0. On mine when you switch to the face camera the screen also goes green along with after you take a picture. I believe it has something to do with the problem the ICS builds have with the video camera not working. I've been looking for a way to fix it but haven't seen anything. So I'll probably just switch roms and try it again.
