Snapchat Incompatible?
ArcuS
For some reason, Snapchat is incompatible with my Galaxy Player. I'm running version 2.3.6. I thought it was compatible with anything over 2.2? Any help or comments is highly appreciated! Thanks!
Its just the file that contains the app. In security settings on your device, you have to have "unknown sources" checked to install one :thumbup:
I PMd you with more info man
Typical Play Store crap. since they added that compatibility thing, 90% of the apps listed as 'not compatible with your device' would in fact work perfectly fine if you side-loaded them. unfortunately, Play doesn't offer a 'download at your own risk' option which sucks as if it's a paid app you got somewhere at one time, such as NBA Jam from EA Games, you can't email the dev for the file as EA is a huge company, and for reasons i still as of yet fail to grasp, it is 'not compatible' with my NEXUS 10!
for a time, Google+ was listed as 'not compatible' with the Nexus 7 too. for that i found it more funny than a problem.
With Play Store version 3.10, the compatibility filter looked at the Device type and make/model in the build.prop file, editable via rooting, and you could force-install by simply changing it to a compatible device which removed the not compatible notice. but i think that stopped working more recently. i had a Kindle Fire that i rooted and tried to fake out as a Nexus 7, but Play Store still refused to allow me to download something the Nexus 7 was compatible with, apparently it was still being reported as a Kindle Fire and at the time, 90% of Play Store apps wouldn't install on the thing, as it was not even intended to function with the Play Store at the time--rooting and getting Play working was still an unapproved thing then.
