Help Snote bug
Hi, I bought a GN2 on nov 2. The Snote apk was running well at this moment.
Since last week I'm not able to insert any image, photos or clipart in the application. I've use Reset Default parameter but the problem still the same.
I would like to delete the Snote apk and reinstall it but this is a system apk and my phone dosn't allow me to delete it.
Need help, thanks.
Need help, thanks.
Can't you go into applications/snote and then clear data or something similar?
Yes I have donne it but it was the same. I just call Samsung support and they help me to reboot my phone and the problem is fix now.
I will ha ve to redownload all my applications now :( (6 pages) but the apk is ok.
Thank you for helping.
I'm very lucky. I don't know how many parameters there is in the GN2 but I found the one that create problem with Snote apk.
In Developer Options parameters, if the "Do not keep activities" is active you will not be able to insert an image, photo or clipart.
I just want to share this information, I think that it should be add to the bug list (if there is one !!!)
thanks, Claude.
