Help snote while dialing the phone
eddie8
Hi guys im sure this can be done but how can you have a note stored in snote on the screen while dialing a phone number off of the snote itself? Want to read the number off the snote while dialing the number..if that makes sense. I have the verizon note2
Dialer doesnt work on Multi-view. At least not on my AT&T N2.
Mine either.
But I can have the dialer open and use the multi tab to open Snote, but then have to switch back and forth between them using the home long-press. The good news is that with a 10 digit number you should only have to do it once.
I know it doesn't solve the problem exactly as you want it to, but you if you enter the number into S Note using text mode you can then copy & paste it into your dialler as a workaround until you find the "proper" answer.
