I still have the same 3g/4g dropouts. Actually worse than before. Most time when I reboot, I need to use a restart connections app to get it working, Then periodically I see it dropping throughout the day.
How can i remove the update?
Thanks
Now what if I boot to recovery mode and do a wipe/factory reset.
Will this put it back to the full shipped OS?
thanks
That won't put you back to the system version you were on before you applied the update. All that will do is clear your data.
So how does he revert to 100% stock?
... Thom
... Thom
Can't be done until someone unlocks the bootloader. Once you flash a new kernal and radio there is no going back.
What version of .893 are you on? I am on 7 and I have noticed a dramatic improvement.
I am on 5.7.893 and have noticed more dropouts on 3G. I am in a 3G only data atm. I dont notice dropouts on 4G when I do have it but recently 3G has been dropping where I used to never had drops. I can say the signal is a little better as I can get 3G where i could not but 3G drops and sometimes a reboot/airplane mode helps. I had one time where I had to do a battery pull.
I'm on 5.7.893 and I have to use 3g since 4g is not available in my area yet.
I still see drop out, seems to be more then before.
Im in a 3g area only... I have had zero issues with data since updating... I was close to giving up on the bionic until I updated... has been smooth sailing since!!!
I am on 5.7.893 and getting tons of drop outs. If I do go back into the store is there a way to flash back so it looks like stock (even if the radio and kernels are different?) I'm still in my 14 day free swap option and considering the razr
I think I have 5.7.893. About phone says so, but I think my rom puts that there. Is there any other way to know for sure? I haven't see a difference since loading it.
Dumb question, but is this the official update we are talking about from our provider or the rooted version? Thanks
I would just use DroidTh3ory's R3root Program to revert your system back to 886.
Your baseband will still be 7.893 but unless you have a really smart rep (haha yeah right) then nobody will be none the wiser.
Root really doesn't have anything to do with the update per say. This update is not the "official" update but it is from Motorola, the "official" update may or may not end up being the leaked one, time will tell.
Ha ha true enough thanks
