So I did a hard reset
albanymike
So I did a hard reset and got ride of the proxies and use A IP some guy from another form sad was a corporate one and 15oo kps on 3G and 6oookps on 4G. Only problem I have is the touch tones, when you have to hit 1 or 3 it does not pick it up and I have to redial? It only has happens on boost, bank of america no problems?
Tones as in using an automated touch tone interface? In that case you may need to set your touch tone length from normal to long
Codegerm
where is it? I saw touch tone but that only make it not make sound when you type a no.
are you on FK23? I know you bring up the phone dial pad then hit the menu button then call settings and scroll down to DTMF tones and click it
Codegerm
I found it and put it on long. I'm on Fl22 4.0.4. I called BOFA Walgreen's Strait talk and a few others no problem, only boost? So I'm gonna keep the phone now I have good data figured out and some 4G.
