So now that is off do I just flash the rom like I normally would in the orig recovery? the teamwin one? I've always used 4-ext or w.e its called is s-off flashing same way? Kinda confused..
In their devices, HTC have installed a sort of security check whose level is determined by S-OFF/S-ON. Essentially, this security level is a flag stored on the device’s radio that checks signature images for any firmware before it is allowed to be written to system memory. This hinders using any custom ROMs, splash images, recovery etc., and also restricts access to the NAND flash memory. However, when security level is set to S-OFF, the signature check is bypassed, allowing a user to upload custom firmware images, unsigned boot, recovery, splash and HBOOT images, as well as official firmware that has been modified, this enabling maximum customization of your HTC Android device.
Furthermore, S-OFF also reduces restrictions on accessing the NAND flash memory on the device, allowing all partitions (including
/system) to be mounted in write mode while the operating system is booted.
to answer your question, you can still flash roms through recovery, like you used to unless you switched recoveries for some reason. (still should be similar.)
