Root So im on cm6 now
xtreemgreen
The install went without a problem.. I had to airplane mode it and reboot for the clock to set to the right time..It is faster then icarus, but I now have more programs auto running then I did with icarus..
Messaging wont shut down at all and it uses 15.3mb..
SD Speed increase shuts down, but comes right back up using 9mb..
Superuser does the same thing using 9.2mb..
I actually have less memory(on the phone) on cm6 then I did with icarus..
But anyway, is there away to change the top info bar from white to black? It was black on icarus, now its back to white..
On the stock rom and icarus, I use to be able to hit the menu key twice to unlock the phone, now I cant, I have to slide on the screen..
Glad you got it figured out man! Good for you.
To change your status bar:
Menu/Settings/CyanogenModSettings/UserInterface/TweaksExtras/Select a theme/ STOCK_Black
