Title says it all. was messing around with pimp my rom and restarted. Not able to boot up anymore.
i have adb set up, but not able to push/install stock system.img, boot.img, or recovery.img
all are on the SD card root folder. i was rooted but wiped data/cache in hopes of factory reset? that did't work. so now im at my wits end. i already called VM and my phone is in backorder i.e not avail. so now im waiting for my replacement phone to become avail. but would try n see if anyone can lend a hand and in return paypal you some thank you moneys
ran n MD5 shows my build.prop is not coming up the same so i think thats the root of my problem.
I have skype, mumble server, team viewer.
. ran n MD5 shows my build.prop is not coming up the same so i think thats the root of my problem.
