Every four or five texts, while I'm in the middle of typing on the soft keyboard, the keyboard will randomly disappear and boot me back to the messaging thread I was in. Then when I touch in the text box to bring the keyboard back up, all the words I previously typed are there, but anything else I type from that point on will not show up on the display. I can keep on typing anyway, and when I hit send or back out, everything I typed did indead get input into the text box, but it is extremely annoying none the less.
The only solution I've found so far is to kill the messaging app with advanced task killer, and then it will work as it should for a little while longer.
I am currently using Better Keyboard, but I'm almost positive I remember it happening before I installed that as well.
Anyone have any ideas?
