Hi guys-- I'm wondering if anyone has any suggestions here...
When I am in a call on my Sprint HTC Hero, if I bring up the touch-keypad, hit the number 1 and then slide the keypad away, I get a message "Starting MMI sequence" and the call disconnects. The reason I discovered this is because I use Google Voice and I need to press 1 to accept a call or 2 to send it to voicemail. But, when I press 1 and slide away the keypad, it disconnects. This does not happen when I press the actual keypad soft-button to get the keypad to disappear, it only happens when I swipe it down and away. It runs other MMI Sequences, depending on which key I press... (2 and 4 give me a dial tone to make another call, 3 gives me a popup that says "unable to conference calls", etc...) so is this a function of the phone (like a shortcut or something), or is it something that shouldn't be happening? Like I said, I don't think I've noticed it before the last day or so and I can't find anything about it in the manual or on any of the forums.
Should pressing a button on the soft-keypad and swiping the keyboard away while in a call always run an "MMI Sequence"?
Thanks very much for any help or thoughts!
