I would like to recommend an app which I think is very useful. Easy Print.
This app lets you print to your printer from your Android Device.
You need a google account (you should already have one), google chrome installed in your pc and an attached printer.
The soft is free and can be downloaded from the market. I've test it and it works OK and fast.
Links:
Google - Cloud Print
Hope it helps. Thanks.-
Links:
