A
Android Question
Guest
Does anyone know of an app that lets you select less frequently used apps to store them on the sd card and automatically returns them to internal memory when used ? The idea is that certain apps including personal data are moved to the sd card so you can have a lot more apps than previously possible. Of course, the apps on sd card can not become active and will take a little time to be copied back to internal memory everytime you want to start them, but i'm thinking of apps like travelplanners that you don't use daily.
