Solution: Is your allys 3g gone?
Mitchell4500
My ally lost 3g a long time ago and I figured out what happened pretty quick and I wanted to post it for futer ref for others. So hear it is.
If you loose 3g be sure to
  1. Be sure you didnt remove the com.android.dunserver app. If you did youll have to find a way to reload it.
  2. Try reflashing your ROM
  3. Try doing a factory reset.
  4. Restore your phone back to v6 using one of the guides on the forums.
Hope this helps as it drove me crazy.
