Root Solution please!
Therich
Hey everyone! I got this Motorola Atrix 4g a couple of month ago. Last week I tried to root it, I did it, but after a couple of hours of being rooted, the notification bar goes crazy as if it were broken glass. It only happends when I twist the phone, the screen rotate automatique and the back vertical again, that is when it all starts. I'm going crazy 'cause I can't used it as I would like. I had to deactivate the auto-rotation for the screen to keep using it. The only temporary solution is to turn it off and on again everytime it happens. My android version is 2.3.4 and system version 4.5.91. Does anyone knows how to fix this? Is it possible that unrooting it may help me? I don't really know how to do that.
Thanks everyone!
This should probably be in the "All Things Root" sub-forum - I'm going to ask the mods to move it there. You're more likely to get a response there.
In the mean time, have you tried another Launcher? Say, Launcher Pro instead of MotoBlur?
Atrix 4G - All Things Root
Actual rooting process does not mess with the phone system files. It allows you to though. Its what u do with root that messes it up.
