Oliver Queen
My daughter has a Kids tablet SM-T2105 which was rooted, but for some reason it got stuck on the TWRP recovery a while back so I decided to flash the original stock rom to it. Not knowing much about flashing the stock ROM to an Android, I gathered all the information I needed and did the process using Odin, the stock ROM I downloaded from a reliable source believing that the version of the tablet was USA (since I bought it from Best Buy). Odin says it had been flashed successfully but when the tablet ends the process and reboots I got stuck in bootloop with the Samsung logo flashing.
I tried to access the recovery from there but it doesn't work, so I tried installing the TWRP and cleaning caches, resetting to factory, etc, but nothing seems to work.
I actually tried this process with many different stock ROM versions (XAR region v. 4.1.2 from this place: https://samsung-firmware.org/model/SM-T2105/region/XAR/) but it always stays stuck in bootloop after an apparent successful flashing process.
Also tried Philz touch recovery but nothing seemed to work - same result after flashing: bootloop again!
I honestly don't know what else to do and I'd appreciate if you guys could guide me on this.
Thanks in advance!
Thanks in advance!
