Root [solved CLOSE PLEASE] error compiling framework-res.apk with apkmult.
Spz0
Android Expert
Im needing to edit some xml files in my framework for my ROM, but Im running into problems with the admires framework-res.apk file when I recompile.
By the looks of the log file, it _may_ have something to do with the decompile process in some .9 files I have edited? -- but they run perfect on the phone, so Im a little puzzled.
Here's the log file for decompile/compile:
DECOMPILE
|Sat 06/23/2012 -- 22:53:23.77|
java version "1.6.0_31"
Java(TM) SE Runtime Environment (build 1.6.0_31-b05)
Java HotSpot(TM) Client VM (build 20.6-b01, mixed mode, sharing)
'platform-tools\adb' is not recognized as an internal or external command,
operable program or batch file.
Could Not Find C:\Users\Spz0\Desktop\apk\place-apk-here-for-modding\../place-apk-here-for-modding/signedframework-res.apk
Could Not Find C:\Users\Spz0\Desktop\apk\place-apk-here-for-modding\../place-apk-here-for-modding/unsignedframework-res.apk
I: Loading resource table...
I: Loaded.
I: Decoding file-resources...
W: Cant find 9patch chunk in file: "drawable-mdpi/btn_default_pressed.9.png". Renaming it to *.png.
W: Cant find 9patch chunk in file: "drawable-mdpi/btn_zoom_up_selected.9.png". Renaming it to *.png.
W: Cant find 9patch chunk in file: "drawable-mdpi/timepicker_down_pressed.9.png". Renaming it to *.png.
W: Cant find 9patch chunk in file: "drawable-mdpi/quickcontact_badge_pressed.9.png". Renaming it to *.png.
W: Cant find 9patch chunk in file: "drawable-mdpi/btn_media_player_disabled_selected.9.png". Renaming it to *.png.
W: Cant find 9patch chunk in file: "drawable-mdpi/timepicker_input_pressed.9.png". Renaming it to *.png.
W: Cant find 9patch chunk in file: "drawable-mdpi/tab_focus.9.png". Renaming it to *.png.
W: Cant find 9patch chunk in file: "drawable-mdpi/btn_dropdown_selected.9.png". Renaming it to *.png.
W: Cant find 9patch chunk in file: "drawable-mdpi/status_bar_item_background_pressed.9.png". Renaming it to *.png.
W: Cant find 9patch chunk in file: "drawable-mdpi/menuitem_background_focus.9.png". Renaming it to *.png.
W: Cant find 9patch chunk in file: "drawable-mdpi/btn_default_small_pressed.9.png". Renaming it to *.png.
W: Cant find 9patch chunk in file: "drawable-mdpi/btn_keyboard_key_trans_selected.9.png". Renaming it to *.png.
W: Cant find 9patch chunk in file: "drawable-mdpi/list_selector_background_longpress.9.png". Renaming it to *.png.
W: Cant find 9patch chunk in file: "drawable-mdpi/btn_default_small_selected.9.png". Renaming it to *.png.
W: Cant find 9patch chunk in file: "drawable-mdpi/quickcontact_badge_small_pressed.9.png". Renaming it to *.png.
W: Cant find 9patch chunk in file: "drawable-mdpi/menuitem_background_pressed.9.png". Renaming it to *.png.
W: Cant find 9patch chunk in file: "drawable-mdpi/quickcontact_nobadge_pressed.9.png". Renaming it to *.png.
W: Cant find 9patch chunk in file: "drawable-mdpi/btn_zoom_up_disabled_focused.9.png". Renaming it to *.png.
W: Cant find 9patch chunk in file: "drawable-mdpi/timepicker_up_disabled_focused.9.png". Renaming it to *.png.
W: Cant find 9patch chunk in file: "drawable-mdpi/btn_search_dialog_pressed.9.png". Renaming it to *.png.
W: Cant find 9patch chunk in file: "drawable-mdpi/highlight_selected.9.png". Renaming it to *.png.
W: Cant find 9patch chunk in file: "drawable-mdpi/btn_zoom_up_pressed.9.png". Renaming it to *.png.
W: Cant find 9patch chunk in file: "drawable-mdpi/btn_default_selected.9.png". Renaming it to *.png.
W: Cant find 9patch chunk in file: "drawable-mdpi/btn_keyboard_key_trans_pressed.9.png". Renaming it to *.png.
W: Cant find 9patch chunk in file: "drawable-mdpi/btn_erase_selected.9.png". Renaming it to *.png.
W: Cant find 9patch chunk in file: "drawable-mdpi/timepicker_down_selected.9.png". Renaming it to *.png.
W: Cant find 9patch chunk in file: "drawable-mdpi/timepicker_down_disabled_focused.9.png". Renaming it to *.png.
W: Cant find 9patch chunk in file: "drawable-mdpi/gallery_unselected_pressed.9.png". Renaming it to *.png.
W: Cant find 9patch chunk in file: "drawable-mdpi/btn_zoom_down_selected.9.png". Renaming it to *.png.
W: Cant find 9patch chunk in file: "drawable-mdpi/tab_press.9.png". Renaming it to *.png.
W: Cant find 9patch chunk in file: "drawable-mdpi/btn_dropdown_disabled_focused.9.png". Renaming it to *.png.
W: Cant find 9patch chunk in file: "drawable-mdpi/gallery_selected_pressed.9.png". Renaming it to *.png.
W: Cant find 9patch chunk in file: "drawable-mdpi/list_selector_background_pressed.9.png". Renaming it to *.png.
W: Cant find 9patch chunk in file: "drawable-mdpi/frame_gallery_thumb_pressed.9.png". Renaming it to *.png.
W: Cant find 9patch chunk in file: "drawable-mdpi/timepicker_input_selected.9.png". Renaming it to *.png.
W: Cant find 9patch chunk in file: "drawable-mdpi/btn_default_normal_disable_focused.9.png". Renaming it to *.png.
W: Cant find 9patch chunk in file: "drawable-mdpi/btn_search_dialog_voice_pressed.9.png". Renaming it to *.png.
W: Cant find 9patch chunk in file: "drawable-mdpi/btn_erase_pressed.9.png". Renaming it to *.png.
W: Cant find 9patch chunk in file: "drawable-mdpi/quickcontact_nobadge_highlight.9.png". Renaming it to *.png.
W: Cant find 9patch chunk in file: "drawable-mdpi/jog_tab_bar_left_end_confirm_yellow.9.png". Renaming it to *.png.
W: Cant find 9patch chunk in file: "drawable-mdpi/jog_tab_bar_right_end_confirm_green.9.png". Renaming it to *.png.
W: Cant find 9patch chunk in file: "drawable-mdpi/btn_zoom_down_pressed.9.png". Renaming it to *.png.
W: Cant find 9patch chunk in file: "drawable-mdpi/btn_default_small_normal_disable_focused.9.png". Renaming it to *.png.
W: Cant find 9patch chunk in file: "drawable-mdpi/list_selector_background_focus.9.png". Renaming it to *.png.
W: Cant find 9patch chunk in file: "drawable-mdpi/jog_tab_bar_right_end_confirm_yellow.9.png". Renaming it to *.png.
W: Cant find 9patch chunk in file: "drawable-mdpi/spinner_press.9.png". Renaming it to *.png.
W: Cant find 9patch chunk in file: "drawable-mdpi/btn_media_player_selected.9.png". Renaming it to *.png.
W: Cant find 9patch chunk in file: "drawable-mdpi/btn_zoom_down_disabled_focused.9.png". Renaming it to *.png.
W: Cant find 9patch chunk in file: "drawable-mdpi/btn_media_player_pressed.9.png". Renaming it to *.png.
W: Cant find 9patch chunk in file: "drawable-mdpi/editbox_background_focus_yellow.9.png". Renaming it to *.png.
W: Cant find 9patch chunk in file: "drawable-mdpi/timepicker_up_selected.9.png". Renaming it to *.png.
W: Cant find 9patch chunk in file: "drawable-mdpi/grid_selector_background_focus.9.png". Renaming it to *.png.
W: Cant find 9patch chunk in file: "drawable-mdpi/btn_search_dialog_voice_selected.9.png". Renaming it to *.png.
W: Cant find 9patch chunk in file: "drawable-mdpi/btn_dropdown_pressed.9.png". Renaming it to *.png.
W: Cant find 9patch chunk in file: "drawable-mdpi/jog_tab_bar_left_end_confirm_green.9.png". Renaming it to *.png.
W: Cant find 9patch chunk in file: "drawable-mdpi/grid_selector_background_pressed.9.png". Renaming it to *.png.
W: Cant find 9patch chunk in file: "drawable-mdpi/gallery_selected_focused.9.png". Renaming it to *.png.
W: Cant find 9patch chunk in file: "drawable-mdpi/timepicker_up_pressed.9.png". Renaming it to *.png.
W: Cant find 9patch chunk in file: "drawable-mdpi/frame_gallery_thumb_selected.9.png". Renaming it to *.png.
W: Cant find 9patch chunk in file: "drawable-mdpi/status_bar_item_background_focus.9.png". Renaming it to *.png.
W: Cant find 9patch chunk in file: "drawable-mdpi/spinner_select.9.png". Renaming it to *.png.
W: Cant find 9patch chunk in file: "drawable-mdpi/highlight_pressed.9.png". Renaming it to *.png.
W: Cant find 9patch chunk in file: "drawable-mdpi/btn_search_dialog_selected.9.png". Renaming it to *.png.
I: Decoding values*/* XMLs...
I: Done.
COMPILE
I: Copying assets and libs...
W: Could not find sources
I: Checking whether resources has changed...
I: Building resources...
Exception in thread "main" brut.androlib.AndrolibException: brut.common.BrutException: could not exec command: [aapt, p, -F, C:\Users\Spz0\AppData\Local\Temp\APKTOOL5104236788858254714.tmp, -x, -S, C:\Users\Spz0\Desktop\apk\platform-tools\..\projects\framework-res.apk\res, -M, C:\Users\Spz0\Desktop\apk\platform-tools\..\projects\framework-res.apk\AndroidManifest.xml]
at brut.androlib.res.AndrolibResources.aaptPackage(AndrolibResources.java:193)
at brut.androlib.Androlib.buildResourcesFull(Androlib.java:302)
at brut.androlib.Androlib.buildResources(Androlib.java:249)
at brut.androlib.Androlib.build(Androlib.java:172)
at brut.androlib.Androlib.build(Androlib.java:155)
at brut.apktool.Main.cmdBuild(Main.java:182)
at brut.apktool.Main.main(Main.java:67)
Caused by: brut.common.BrutException: could not exec command: [aapt, p, -F, C:\Users\Spz0\AppData\Local\Temp\APKTOOL5104236788858254714.tmp, -x, -S, C:\Users\Spz0\Desktop\apk\platform-tools\..\projects\framework-res.apk\res, -M, C:\Users\Spz0\Desktop\apk\platform-tools\..\projects\framework-res.apk\AndroidManifest.xml]
at brut.util.OS.exec(OS.java:87)
at brut.androlib.res.AndrolibResources.aaptPackage(AndrolibResources.java:191)
... 6 more
Caused by: java.io.IOException: Cannot run program "aapt": CreateProcess error=2, The system cannot find the file specified
at java.lang.ProcessBuilder.start(Unknown Source)
at java.lang.Runtime.exec(Unknown Source)
at brut.util.OS.exec(OS.java:78)
... 7 more
Caused by: java.io.IOException: CreateProcess error=2, The system cannot find the file specified
at java.lang.ProcessImpl.create(Native Method)
at java.lang.ProcessImpl.<init>(Unknown Source)
at java.lang.ProcessImpl.start(Unknown Source)
... 11 more
Unable to access jarfile apktool.jar
^CUnable to access jarfile apktool.jar
When its states "renaming to *.png" I notice that it actually creates a dup of the file but removes the .9 extension...
Im thinking this may be why?
So, is there any way to stop this from happening (without re-editing all the above mentioned png's which work fine in the ROM iteself)?
*edit:: I removed the mdpi folder in projects, and replaced it with an unaltered copy from the apk itself, and tried to recompile. Still ran into the same error on recompile.
Bahh... I may just end up re-editing all the suspect png files, just so its not sloppy..
Cheers. :)
Mod Please close thread. Solved.
I just re-edited all the png files, working fine now.
