I've downloaded 2 copies of the file
com.netflix.mediaclient-2.apk and com.netflix.mediaclient-3.apk and both of them give me an error "There is a problem parsing the package"
Note: I have verified Unknown Sources is checked in settings.
I am running GB...any help would be appreciated.
once you download the APK, what do you have to do to install it? do you need another app to make it work?
There seems to be a lot of first-hand help on your potential problems located here.
After you have it on your phone, I use Astro file (free from market) and you can run the apk file and it will install on your phone. You do need to make sure you have the permissions on your phone set to allow it to install from unknown sources.
Tried to download the app from the link but it keeps saying unsuccessful
