*SOLVED* How to unlock a smartphone?
Hello
I am in a desperate need to unlock my old Samsung Captivate. I contacted AT&T and they gave me an unlock code and a set of weird instructions that didn't work. I also put a TMOBILE sim card in and put in the unlock code they gave me but it failed. I only have a few more tries before it locks up forever. I told this to ATT but they told me to contact Samsung who did not respond to my numerous messages. Now I really need some help with my Captivate as I am leaving for Europe on 08/02. Just so you know, I know how to root a phone, I also know how to install a custom ROM in case any of this will be required. I'd appreciate any help you can give me with this. Thank you
EDIT - Also if you need it I can post my IMEI and the unlock code.
Hello
Have you tried any of the unlock code generator patches?
SamsungUnlocker_v1.4 | Samsung Network/Sim Unlock Code Generator/Patcher
Many out there... but the Captivate's been around a while. ;)
So I tried the smartphone unlocker program that was in that youtube video and it gives me an error when I run it.
Here is everything that it says:
One click Unlock for Galaxy S Family
__________________________________________________________
Copy nv_data.bin
* daemon not running. starting it now *
* daemon started successfully *
failed to copy '/efs/nv_data.bin' to './nv_data.bin': Permission denied
Extract code
SGUX v0.92b (C) 2010 By Mark0 & rbnet
Samsung Galaxy Unlock code eXtractor
(based on info by rhcp0112345 & RazvanG)
* Error: unable to find file <.\nv_data.bin>
Could Not Find C:\Users\God\Downloads\Galaxy_S__unlocker_windows\Generate Unlock
Windows\Generate Unlock Windows\nv_data.bin
Please donate to DagentooBoy for the scripting
Please donate to rbnet.it and marcopon for the SGUX utility used in the script
Special thanks to Bowsa2511 for helping with the script
Script complete!
Press any key to continue . . .
EDIT: Do I need to root the phone and add superuser before I run this?
After hours of working on this I finally solved it. Basically what did it for me was one of the links I found on a forum post. Samsung Galaxy S Unlocker
At first I had issues with it not working but here is what I did to make it work.
1. My firmware version was 2.3.5, so I had to flashback to 2.1 to make this work for me. Here is the link where I found the stock 2.1 ROM http://forum.xda-developers.com/showthread.php?t=1300843
2. Then I had to root the phone, the easiest way for me was to download that famous update.zip file, copy it to the phone storage (Root directory), and run it from recovery mode.
3. Then I had to download the Android SDK package so that I could run ADB and ADB shell. Android SDK | Android Developers
4. After I got it, I unziped the whole thing to C:/ADB
5. Then I made sure that I can run adb from the console. To do that right-click computer, hit Properties, hit Advanced System Settings, hit Environment Variables, scroll until you see Path and hit edit, there add the line ;C:\adb\sdk\platform-tools and hit OK until you are out.
6. Then I followed the instructions at Captivate & Vibrant Unlock Instructions
The simple method worked for me, I downloaded the two .bat files and ran them and the phone was magically unlocked.
In addition to that I installed cyanogen mod and the phone runs smooth as butter now. Getting it done was a pain, but I learned a lot in the process. Hope this helps somebody.
