Root SOLVED - Missing WiMax Keys - Update First Post
I don't see how gapps would make a difference. Open a terminal emulator, and run:
su
wimax_mtd
You might need to be on a sense ROM to do that. It should run through some tests.
su
wimax_mtd
i was able to run it on cm 7
Code:
$ export PATH=/data/local/bin:$PATH
$su
#wimax_mtd
Open WiMAX partition ........ OK
Get HTC WiMAX Tag ........ OK
Verify WiMAX Tag (HTC-WiMAX-SQN1130)........ PASS
Read WiMAX partition ........ OK
Check Firwmare Version (4.6.2.2v25641_) ........ 4.6.2.2v25641_
Check Firwmare File ........ MATCH
Dev MAC = 00:18:41:82:44:08
Read properties from flash ..... OK
+ in wmx_PropSetFromFlash.
+ in wmx_CheckPropTag.
- out wmx_CheckPropTag.
  pPropName = persist.wimax.Cold_Boot_Flag
PropNameLen = 28
wmx_PropSetFromFlash: Find matched property name in flash.
        pMemAddr == pPropName = 1
        pPropData = 1
persist.wimax.Cold_Boot_Flag = 1
isColdBoot = 0
// Not Cold Boot: Load properties from flash.
+ in wmx_AllPropSetFromFlash.
  pPropName = prop_exist
readLen = strlen(prop_exist)+1 = 10+1= 11
readLen = strlen(persist.wimax.Cold_Boot_Flag)+1 = 28+1= 29
  pPropData = 1
readLen = strlen(1)+1 = 1+1= 2
  pPropName = persist.wimax.STANDBY_TIME
readLen = strlen(persist.wimax.STANDBY_TIME)+1 = 26+1= 27
  pPropData = 600000
readLen = strlen(600000)+1 = 6+1= 7
  pPropName = persist.wimax.SCAN_RATE
readLen = strlen(persist.wimax.SCAN_RATE)+1 = 23+1= 24
  pPropData = 1800000
readLen = strlen(1800000)+1 = 7+1= 8
  pPropName = persist.wimax.Realm
readLen = strlen(persist.wimax.Realm)+1 = 19+1= 20
  pPropData = @sprintpcs.com
readLen = strlen(@sprintpcs.com)+1 = 14+1= 15
  pPropName = persist.wimax.CenterFrequency
readLen = strlen(persist.wimax.CenterFrequency)+1 = 29+1= 30
  pPropData = 2647000,2657000,2667000
readLen = strlen(2647000,2657000,2667000)+1 = 23+1= 24
  pPropName = persist.wimax.Bandwidth
readLen = strlen(persist.wimax.Bandwidth)+1 = 23+1= 24
  pPropData = 10,10,10
readLen = strlen(10,10,10)+1 = 8+1= 9
  pPropName = persist.wimax.0.Man
readLen = strlen(persist.wimax.0.Man)+1 = 19+1= 20
  pPropData = SEQUANS
readLen = strlen(SEQUANS)+1 = 7+1= 8
  pPropName = persist.wimax.0.Mod
readLen = strlen(persist.wimax.0.Mod)+1 = 19+1= 20
  pPropData = SQN1210
readLen = strlen(SQN1210)+1 = 7+1= 8
  pPropName = persist.wimax.0.FwV
readLen = strlen(persist.wimax.0.FwV)+1 = 19+1= 20
  pPropData = 24836
readLen = strlen(24836)+1 = 5+1= 6
  pPropName = persist.wimax.0.HwV
readLen = strlen(persist.wimax.0.HwV)+1 = 19+1= 20
  pPropData = REV0944
readLen = strlen(REV0944)+1 = 7+1= 8
  pPropName = persist.wimax.0.SwV
readLen = strlen(persist.wimax.0.SwV)+1 = 19+1= 20
  pPropData = 4.6.2.2
readLen = strlen(4.6.2.2)+1 = 7+1= 8
  pPropName = persist.wimax.0.MAC
readLen = strlen(persist.wimax.0.MAC)+1 = 19+1= 20
  pPropData = 00:18:41:82:44:08
readLen = strlen(00:18:41:82:44:08)+1 = 17+1= 18
  pPropName = persist.wimax.0.TO-FUMO-REF
readLen = strlen(persist.wimax.0.TO-FUMO-REF)+1 = 27+1= 28
  pPropData = ./FUMO
readLen = strlen(./FUMO)+1 = 6+1= 7
  pPropName = persist.wimax.TO-WiMAX-REF
readLen = strlen(persist.wimax.TO-WiMAX-REF)+1 = 26+1= 27
  pPropData = ./WiMAXSupp
readLen = strlen(./WiMAXSupp)+1 = 11+1= 12
  pPropName = persist.wimax.IPv4
readLen = strlen(persist.wimax.IPv4)+1 = 18+1= 19
  pPropData = TRUE
readLen = strlen(TRUE)+1 = 4+1= 5
  pPropName = persist.wimax.IPv6
readLen = strlen(persist.wimax.IPv6)+1 = 18+1= 19
  pPropData = TRUE
  pPropName = persist.wimax.ServerInitiated
readLen = strlen(persist.wimax.ServerInitiated)+1 = 29+1= 30
  pPropData = TRUE
  pPropName = persist.wimax.CLInit.PollSuprt
readLen = strlen(persist.wimax.CLInit.PollSuprt)+1 = 30+1= 31
  pPropData = TRUE
  pPropName = persist.wimax.CLInit.PollIntrvl
readLen = strlen(persist.wimax.CLInit.PollIntrvl)+1 = 31+1= 32
  pPropData = -1
readLen = strlen(-1)+1 = 2+1= 3
  pPropName = persist.wimax.WorkMode
readLen = strlen(persist.wimax.WorkMode)+1 = 22+1= 23
  pPropData = 0
readLen = strlen(0)+1 = 1+1= 2
  pPropName = persist.wimax.Session_Conti
readLen = strlen(persist.wimax.Session_Conti)+1 = 27+1= 28
  pPropData = 0
  pPropName = persist.wimax.Scan_Timeout
readLen = strlen(persist.wimax.Scan_Timeout)+1 = 26+1= 27
  pPropData = 1
  pPropName = persist.wimax.Scan_Retry
readLen = strlen(persist.wimax.Scan_Retry)+1 = 24+1= 25
  pPropData = 120
readLen = strlen(120)+1 = 3+1= 4
  pPropName = persist.wimax.Idle_Sleep
readLen = strlen(persist.wimax.Idle_Sleep)+1 = 24+1= 25
  pPropData = 10
readLen = strlen(10)+1 = 2+1= 3
  pPropName = persist.wimax.Entry_RX
readLen = strlen(persist.wimax.Entry_RX)+1 = 22+1= 23
  pPropData = -89
readLen = strlen(-89)+1 = 3+1= 4
  pPropName = persist.wimax.Entry_CINR
readLen = strlen(persist.wimax.Entry_CINR)+1 = 24+1= 25
  pPropData = 4
readLen = strlen(4)+1 = 1+1= 2
  pPropName = persist.wimax.Entry_Delay
readLen = strlen(persist.wimax.Entry_Delay)+1 = 25+1= 26
  pPropData = 300
readLen = strlen(300)+1 = 3+1= 4
  pPropName = persist.wimax.Exit_CINR
readLen = strlen(persist.wimax.Exit_CINR)+1 = 23+1= 24
  pPropData = 2
readLen = strlen(2)+1 = 1+1= 2
  pPropName = persist.wimax.Exit_Delay
readLen = strlen(persist.wimax.Exit_Delay)+1 = 24+1= 25
  pPropData = 2
  pPropName = persist.wimax.0.H-NSP-ID
readLen = strlen(persist.wimax.0.H-NSP-ID)+1 = 24+1= 25
  pPropData = 000004
readLen = strlen(000004)+1 = 6+1= 7
  pPropName = persist.wimax.OperatorName
readLen = strlen(persist.wimax.OperatorName)+1 = 26+1= 27
  pPropData = SPRINT
readLen = strlen(SPRINT)+1 = 6+1= 7
  pPropName = persist.wimax.PollingInterval
readLen = strlen(persist.wimax.PollingInterval)+1 = 29+1= 30
  pPropData =
readLen = strlen()+1 = 0+1= 1
  pPropName = persist.wimax.Primary.Name
readLen = strlen(persist.wimax.Primary.Name)+1 = 26+1= 27
  pPropData =
  pPropName = persist.wimax.Primary.Activated
readLen = strlen(persist.wimax.Primary.Activated)+1 = 31+1= 32
  pPropData = FALSE
readLen = strlen(FALSE)+1 = 5+1= 6
  pPropName = persist.wimax.0.METHOD-TYPE
readLen = strlen(persist.wimax.0.METHOD-TYPE)+1 = 27+1= 28
  pPropData = 13
readLen = strlen(13)+1 = 2+1= 3
  pPropName = persist.wimax.0.VENDOR-ID
readLen = strlen(persist.wimax.0.VENDOR-ID)+1 = 25+1= 26
  pPropData =
  pPropName = persist.wimax.0.VENDOR-TYPE
readLen = strlen(persist.wimax.0.VENDOR-TYPE)+1 = 27+1= 28
  pPropData =
  pPropName = persist.wimax.0.USER-IDENTITY
readLen = strlen(persist.wimax.0.USER-IDENTITY)+1 = 29+1= 30
  pPropData =
  pPropName = persist.wimax.0.PSEUDO-IDENTITY
readLen = strlen(persist.wimax.0.PSEUDO-IDENTITY)+1 = 31+1= 32
  pPropData =
  pPropName = persist.wimax.0.PASSWORD
readLen = strlen(persist.wimax.0.PASSWORD)+1 = 24+1= 25
  pPropData =
  pPropName = persist.wimax.0.REALM
readLen = strlen(persist.wimax.0.REALM)+1 = 21+1= 22
  pPropData = sprintpcs.com
readLen = strlen(sprintpcs.com)+1 = 13+1= 14
  pPropName = persist.wimax.0.USE-PRIVACY
readLen = strlen(persist.wimax.0.USE-PRIVACY)+1 = 27+1= 28
  pPropData =
  pPropName = persist.wimax.0.ENCAPS
readLen = strlen(persist.wimax.0.ENCAPS)+1 = 22+1= 23
  pPropData =
  pPropName = persist.wimax.0.VFY-SRVR-REALM
readLen = strlen(persist.wimax.0.VFY-SRVR-REALM)+1 = 30+1= 31
  pPropData = TRUE
  pPropName = persist.wimax.0.S-RLM.0.S-RLM
readLen = strlen(persist.wimax.0.S-RLM.0.S-RLM)+1 = 29+1= 30
  pPropName = persist.wimax.0.To-IP-REF
readLen = strlen(persist.wimax.0.To-IP-REF)+1 = 25+1= 26
  pPropData = ./IP
readLen = strlen(./IP)+1 = 4+1= 5
Dump all properties in Flash. (262144) ........ OK
total time: 1.404 sec!
after loosing 4g for i dont know how long :confused: :rolleyes: i am FINALLY back on 4g!! :D:D:D:D:D:D
lots of thanks to everyone here and those at xda! :cool:
this is cm7 with savage-kernel v1.6 sbc cfs havs :D
Okay, so what did you ultimately do between it not working a bit ago, and it working now?
last night i got tired/frustrated with trouble shooting it and gave up. at this point i was so frustrated that i told myself, screw it - its not ever gonna get fixed - flash cm7 and be done. flashed cm7 and went to bed.
got up this morning and starting re-customizing my screens and installing my apps. just for grins i went into rom manager and did the "fix permissions". it fixed over 100 issues :eek: so who knows what exactly happened or what it fixed. then i got busy doing my accounting homework.
after homework was done, i decided wth, might as well try wimax again. it went from scanning to connecting to connected all in a few seconds. i thought wth, no way. i checked the ip screen and sure enough i was connected.
something tells me that the fix permissions did something. but whatever it did :D im sure in the hell happy with having my wimax back!!
here is the fix permissions log
Code:
/data/data/com.koushikdutta.rommanager/files/fix_permissions 2.04 started at 03-05-2011 11:30:39
Processing (1 of 175): com.google.android.location...
Changing permissions for: /data/data/com.google.android.location from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Changing permissions for: /data/data/com.google.android.location/files/DATA_Preferences from 'rw-rw----' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.google.android.location/files/gls.platform.key from 'rw-------' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.google.android.location/files/cache.cell from 'rw-------' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.google.android.location/files/cache.wifi from 'rw-------' to 'rwxrwx--x' (771)
Processing (2 of 175): com.imdb.mobile...
Changing permissions for: /data/data/com.imdb.mobile from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (3 of 175): com.android.voicedialer...
Changing permissions for: /data/data/com.android.voicedialer from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (4 of 175): com.android.launcher...
Changing permissions for: /data/data/com.android.launcher from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Changing permissions for: /data/data/com.android.launcher/databases/launcher.db-shm from 'rw-r--r--' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.android.launcher/databases/launcher.db-wal from 'rw-r--r--' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.android.launcher/files/launcher.preferences from 'rw-rw----' to 'rwxrwx--x' (771)
Processing (5 of 175): com.android.defcontainer...
Changing permissions for: /data/data/com.android.defcontainer from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (6 of 175): com.tesseractmobile.solitairefreepack...
Changing permissions for: /data/data/com.tesseractmobile.solitairefreepack from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Changing permissions for: /data/data/com.tesseractmobile.solitairefreepack/databases from 'rwxrwxrwx' to 'rwxrwx--x' (771)
Changing user ownership for: /data/data/com.tesseractmobile.solitairefreepack/databases from '0' to '10068'
Changing group ownership for: /data/data/com.tesseractmobile.solitairefreepack/databases from '0' to '10068'
Changing permissions for: /data/data/com.tesseractmobile.solitairefreepack/databases/stats.db from 'rw-rw-rw-' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.tesseractmobile.solitairefreepack/databases/gamedata.db from 'rw-rw-rw-' to 'rw-rw----' (660)
Changing user ownership for: /data/data/com.tesseractmobile.solitairefreepack/databases/stats.db from '0' to '10068'
Changing user ownership for: /data/data/com.tesseractmobile.solitairefreepack/databases/gamedata.db from '0' to '10068'
Changing group ownership for: /data/data/com.tesseractmobile.solitairefreepack/databases/stats.db from '0' to '10068'
Changing group ownership for: /data/data/com.tesseractmobile.solitairefreepack/databases/gamedata.db from '0' to '10068'
Changing permissions for: /data/data/com.tesseractmobile.solitairefreepack/shared_prefs from 'rwxrwxrwx' to 'rwxrwx--x' (771)
Changing user ownership for: /data/data/com.tesseractmobile.solitairefreepack/shared_prefs from '0' to '10068'
Changing group ownership for: /data/data/com.tesseractmobile.solitairefreepack/shared_prefs from '0' to '10068'
Changing permissions for: /data/data/com.tesseractmobile.solitairefreepack/shared_prefs/SolitairePrefs.xml from 'rw-rw-rw-' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.tesseractmobile.solitairefreepack/shared_prefs/com.tesseractmobile.solitairefreepack_preferences.xml from 'rw-rw-rw-' to 'rw-rw----' (660)
Changing user ownership for: /data/data/com.tesseractmobile.solitairefreepack/shared_prefs/SolitairePrefs.xml from '0' to '10068'
Changing user ownership for: /data/data/com.tesseractmobile.solitairefreepack/shared_prefs/com.tesseractmobile.solitairefreepack_preferences.xml from '0' to '10068'
Changing group ownership for: /data/data/com.tesseractmobile.solitairefreepack/shared_prefs/SolitairePrefs.xml from '0' to '10068'
Changing group ownership for: /data/data/com.tesseractmobile.solitairefreepack/shared_prefs/com.tesseractmobile.solitairefreepack_preferences.xml from '0' to '10068'
Processing (7 of 175): com.levelup.beautifulwidgets...
Changing user ownership for: /data/app/com.levelup.beautifulwidgets.apk from '0' to '1000'
Changing group ownership for: /data/app/com.levelup.beautifulwidgets.apk from '0' to '1000'
Changing permissions for: /data/app/com.levelup.beautifulwidgets.apk from 'rw-rw-rw-' to 'rw-r--r--' (644)
Changing permissions for: /data/data/com.levelup.beautifulwidgets from 'rwxrwxrwx' to 'rwxr-xr-x' (755)
Changing user ownership for: /data/data/com.levelup.beautifulwidgets from '0' to '10109'
Changing group ownership for: /data/data/com.levelup.beautifulwidgets from '0' to '10109'
Changing permissions for: /data/data/com.levelup.beautifulwidgets/databases from 'rwxrwxrwx' to 'rwxrwx--x' (771)
Changing user ownership for: /data/data/com.levelup.beautifulwidgets/databases from '0' to '10109'
Changing group ownership for: /data/data/com.levelup.beautifulwidgets/databases from '0' to '10109'
Changing permissions for: /data/data/com.levelup.beautifulwidgets/databases/Pictures.sqlite from 'rw-rw-rw-' to 'rw-rw----' (660)
Changing user ownership for: /data/data/com.levelup.beautifulwidgets/databases/Pictures.sqlite from '0' to '10109'
Changing group ownership for: /data/data/com.levelup.beautifulwidgets/databases/Pictures.sqlite from '0' to '10109'
Changing permissions for: /data/data/com.levelup.beautifulwidgets/shared_prefs from 'rwxrwxrwx' to 'rwxrwx--x' (771)
Changing user ownership for: /data/data/com.levelup.beautifulwidgets/shared_prefs from '0' to '10109'
Changing group ownership for: /data/data/com.levelup.beautifulwidgets/shared_prefs from '0' to '10109'
Processing (8 of 175): com.google.android.marvin.soundback...
Changing permissions for: /data/data/com.google.android.marvin.soundback from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (9 of 175): jackpal.androidterm2...
Changing permissions for: /data/data/jackpal.androidterm2 from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (10 of 175): com.android.contacts...
Changing permissions for: /data/data/com.android.contacts from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (11 of 175): com.coffeecup.smoothies...
Changing permissions for: /data/data/com.coffeecup.smoothies from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (12 of 175): com.clearchannel.iheartradio.controller...
Changing user ownership for: /data/app/com.clearchannel.iheartradio.controller.apk from '0' to '1000'
Changing group ownership for: /data/app/com.clearchannel.iheartradio.controller.apk from '0' to '1000'
Changing permissions for: /data/app/com.clearchannel.iheartradio.controller.apk from 'rw-rw-rw-' to 'rw-r--r--' (644)
Changing permissions for: /data/data/com.clearchannel.iheartradio.controller from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (13 of 175): org.openintents.colorpicker...
Changing user ownership for: /data/app/org.openintents.colorpicker.apk from '0' to '1000'
Changing group ownership for: /data/app/org.openintents.colorpicker.apk from '0' to '1000'
Changing permissions for: /data/app/org.openintents.colorpicker.apk from 'rw-rw-rw-' to 'rw-r--r--' (644)
Changing permissions for: /data/data/org.openintents.colorpicker from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (14 of 175): com.levelup.bw.forecast...
Changing user ownership for: /data/app/com.levelup.bw.forecast.apk from '0' to '1000'
Changing group ownership for: /data/app/com.levelup.bw.forecast.apk from '0' to '1000'
Changing permissions for: /data/app/com.levelup.bw.forecast.apk from 'rw-rw-rw-' to 'rw-r--r--' (644)
Changing permissions for: /data/data/com.levelup.bw.forecast from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (15 of 175): org.koxx.pure_calendar...
Changing user ownership for: /data/app/org.koxx.pure_calendar.apk from '0' to '1000'
Changing group ownership for: /data/app/org.koxx.pure_calendar.apk from '0' to '1000'
Changing permissions for: /data/app/org.koxx.pure_calendar.apk from 'rw-rw-rw-' to 'rw-r--r--' (644)
Changing permissions for: /data/data/org.koxx.pure_calendar from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Changing permissions for: /data/data/org.koxx.pure_calendar/files from 'rwxrwxrwx' to 'rwxrwx--x' (771)
Changing user ownership for: /data/data/org.koxx.pure_calendar/files from '0' to '10132'
Changing group ownership for: /data/data/org.koxx.pure_calendar/files from '0' to '10132'
Changing permissions for: /data/data/org.koxx.pure_calendar/files/background_widget_13_port.png from 'rw-rw-rw-' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/org.koxx.pure_calendar/files/background_widget_17_land.png from 'rw-rw-rw-' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/org.koxx.pure_calendar/files/background_widget_17_port.png from 'rw-rw-rw-' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/org.koxx.pure_calendar/files/background_widget_18_land.png from 'rw-rw-rw-' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/org.koxx.pure_calendar/files/background_widget_18_port.png from 'rw-rw-rw-' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/org.koxx.pure_calendar/files/background_widget_20_land.png from 'rw-rw-rw-' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/org.koxx.pure_calendar/files/background_widget_20_port.png from 'rw-rw-rw-' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/org.koxx.pure_calendar/files/background_widget_24_land.png from 'rw-rw-rw-' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/org.koxx.pure_calendar/files/background_widget_47_port.png from 'rw-rw-rw-' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/org.koxx.pure_calendar/files/background_widget_62_land.png from 'rw-rw-rw-' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/org.koxx.pure_calendar/files/background_widget_62_port.png from 'rw-rw-rw-' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/org.koxx.pure_calendar/files/background_widget_109_port.png from 'rw-rw-rw-' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/org.koxx.pure_calendar/files/background_widget_117_land.png from 'rw-rw-rw-' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/org.koxx.pure_calendar/files/background_widget_117_port.png from 'rw-rw-rw-' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/org.koxx.pure_calendar/files/background_widget_13_land.png from 'rw-rw-rw-' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/org.koxx.pure_calendar/files/background_widget_24_port.png from 'rw-rw-rw-' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/org.koxx.pure_calendar/files/background_widget_45_land.png from 'rw-rw-rw-' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/org.koxx.pure_calendar/files/background_widget_47_land.png from 'rw-rw-rw-' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/org.koxx.pure_calendar/files/background_widget_45_port.png from 'rw-rw-rw-' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/org.koxx.pure_calendar/files/background_widget_109_land.png from 'rw-rw-rw-' to 'rwxrwx--x' (771)
Changing user ownership for: /data/data/org.koxx.pure_calendar/files/background_widget_13_port.png from '0' to '10132'
Changing user ownership for: /data/data/org.koxx.pure_calendar/files/background_widget_17_land.png from '0' to '10132'
Changing user ownership for: /data/data/org.koxx.pure_calendar/files/background_widget_17_port.png from '0' to '10132'
Changing user ownership for: /data/data/org.koxx.pure_calendar/files/background_widget_18_land.png from '0' to '10132'
Changing user ownership for: /data/data/org.koxx.pure_calendar/files/background_widget_18_port.png from '0' to '10132'
Changing user ownership for: /data/data/org.koxx.pure_calendar/files/background_widget_20_land.png from '0' to '10132'
Changing user ownership for: /data/data/org.koxx.pure_calendar/files/background_widget_20_port.png from '0' to '10132'
Changing user ownership for: /data/data/org.koxx.pure_calendar/files/background_widget_24_land.png from '0' to '10132'
Changing user ownership for: /data/data/org.koxx.pure_calendar/files/background_widget_47_port.png from '0' to '10132'
Changing user ownership for: /data/data/org.koxx.pure_calendar/files/background_widget_62_land.png from '0' to '10132'
Changing user ownership for: /data/data/org.koxx.pure_calendar/files/background_widget_62_port.png from '0' to '10132'
Changing user ownership for: /data/data/org.koxx.pure_calendar/files/background_widget_109_port.png from '0' to '10132'
Changing user ownership for: /data/data/org.koxx.pure_calendar/files/background_widget_117_land.png from '0' to '10132'
Changing user ownership for: /data/data/org.koxx.pure_calendar/files/background_widget_117_port.png 7 (771)
Processing (57 of 175): com.motalen.batterytimelite...
Changing permissions for: /data/data/com.motalen.batterytimelite from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (58 of 175): com.google.android.googlequicksearchbox...
Changing permissions for: /data/data/com.google.android.googlequicksearchbox from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (59 of 175): com.facebook.katana...
Changing permissions for: /data/data/com.facebook.katana from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Changing permissions for: /data/data/com.facebook.katana/files/BG97 from 'rw-------' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.facebook.katana/files/rC5I from 'rw-------' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.facebook.katana/files/15rR from 'rw-------' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.facebook.katana/files/1Qzk from 'rw-------' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.facebook.katana/files/gl60 from 'rw-------' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.facebook.katana/files/bn38 from 'rw-------' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.facebook.katana/files/6Q86 from 'rw-------' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.facebook.katana/files/qVFX from 'rw-------' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.facebook.katana/files/f6Sp from 'rw-------' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.facebook.katana/files/Fq9T from 'rw-------' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.facebook.katana/files/uiRk from 'rw-------' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.facebook.katana/files/EBQ2 from 'rw-------' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.facebook.katana/files/J4hP from 'rw-------' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.facebook.katana/files/5BDT from 'rw-------' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.facebook.katana/files/B4Ob from 'rw-------' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.facebook.katana/databases/webviewCache.db-shm from 'rw-r--r--' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.facebook.katana/databases/webviewCache.db-wal from 'rw-r--r--' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.facebook.katana/databases/webview.db-shm from 'rw-r--r--' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.facebook.katana/databases/webview.db-wal from 'rw-r--r--' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.facebook.katana/databases/fb.db-wal from 'rw-r--r--' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.facebook.katana/databases/fb.db-shm from 'rw-r--r--' to 'rw-rw----' (660)
Processing (60 of 175): com.android.providers.drm...
Changing permissions for: /data/data/com.android.providers.drm from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Changing permissions for: /data/data/com.android.providers.drm/databases/drm.db-shm from 'rw-r--r--' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.android.providers.drm/databases/drm.db-wal from 'rw-r--r--' to 'rw-rw----' (660)
Processing (61 of 175): com.cyanogenmod.updatenotify...
Changing permissions for: /data/data/com.cyanogenmod.updatenotify from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (62 of 175): com.android.musicvis...
Changing permissions for: /data/data/com.android.musicvis from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (63 of 175): com.adobe.flashplayer...
Changing user ownership for: /data/app/com.adobe.flashplayer.apk from '0' to '1000'
Changing group ownership for: /data/app/com.adobe.flashplayer.apk from '0' to '1000'
Changing permissions for: /data/app/com.adobe.flashplayer.apk from 'rw-rw-rw-' to 'rw-r--r--' (644)
Changing permissions for: /data/data/com.adobe.flashplayer from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (64 of 175): com.tmobile.theme.Cyanbread...
Changing permissions for: /data/data/com.tmobile.theme.Cyanbread from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (65 of 175): com.android.wallpaper.livepicker...
Changing permissions for: /data/data/com.android.wallpaper.livepicker from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (66 of 175): com.android.development...
Changing permissions for: /data/data/com.android.development from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (67 of 175): com.android.packageinstaller...
Changing permissions for: /data/data/com.android.packageinstaller from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (68 of 175): com.android.providers.telephony...
Changing permissions for: /data/data/com.android.providers.telephony from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Changing permissions for: /data/data/com.android.providers.telephony/databases/mmssms.db-wal from 'rw-r--r--' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.android.providers.telephony/databases/telephony.db-wal from 'rw-r--r--' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.android.providers.telephony/databases/telephony.db-shm from 'rw-r--r--' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.android.providers.telephony/databases/mmssms.db-shm from 'rw-r--r--' to 'rw-rw----' (660)
Processing (69 of 175): com.greenecomputing.linpack...
Changing user ownership for: /data/app/com.greenecomputing.linpack.apk from '0' to '1000'
Changing group ownership for: /data/app/com.greenecomputing.linpack.apk from '0' to '1000'
Changing permissions for: /data/app/com.greenecomputing.linpack.apk from 'rw-rw-rw-' to 'rw-r--r--' (644)
Changing permissions for: /data/data/com.greenecomputing.linpack from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (70 of 175): com.android.providers.subscribedfeeds...
Changing permissions for: /data/data/com.android.providers.subscribedfeeds from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (71 of 175): com.svox.pico...
Changing permissions for: /data/data/com.svox.pico from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (72 of 175): com.th.android.widget.gTabsimiClock...
Changing user ownership for: /data/app/com.th.android.widget.gTabsimiClock.apk from '0' to '1000'
Changing group ownership for: /data/app/com.th.android.widget.gTabsimiClock.apk from '0' to '1000'
Changing permissions for: /data/app/com.th.android.widget.gTabsimiClock.apk from 'rw-rw-rw-' to 'rw-r--r--' (644)
Changing permissions for: /data/data/com.th.android.widget.gTabsimiClock from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (73 of 175): de.mangelow.network...
Changing user ownership for: /data/app/de.mangelow.network.apk from '0' to '1000'
Changing group ownership for: /data/app/de.mangelow.network.apk from '0' to '1000'
Changing permissions for: /data/app/de.mangelow.network.apk from 'rw-rw-rw-' to 'rw-r--r--' (644)
Changing permissions for: /data/data/de.mangelow.network from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (74 of 175): com.mx.browser...
Changing permissions for: /data/data/com.mx.browser from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Changing permissions for: /data/data/com.mx.browser/files/trackball_lights from 'rw-rw-r--' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.mx.browser/files/upfile from 'rwx------' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.mx.browser/app_icons/WebpageIcons.db from 'rw-rw----' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.mx.browser/databases/downloads.db-wal from 'rw-r--r--' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.mx.browser/databases/webviewCache.db-wal from 'rw-r--r--' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.mx.browser/databases/webview.db-wal from 'rw-r--r--' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.mx.browser/databases/downloads.db-shm from 'rw-r--r--' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.mx.browser/databases/webviewCache.db-shm from 'rw-r--r--' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.mx.browser/databases/webview.db-shm from 'rw-r--r--' to 'rw-rw----' (660)
Processing (75 of 175): com.android.email...
Changing permissions for: /data/data/com.android.email from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Changing permissions for: /data/data/com.android.email/files/deviceName from 'rw-------' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.android.email/databases/EmailProviderBody.db-wal from 'rw-r--r--' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.android.email/databases/EmailProvider.db-wal from 'rw-r--r--' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.android.email/databases/EmailProviderBody.db-shm from 'rw-r--r--' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.android.email/databases/EmailProvider.db-shm from 'rw-r--r--' to 'rw-rw----' (660)
Processing (76 of 175): com.google.android.apps.maps...
Changing permissions for: /data/data/com.google.android.apps.maps from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Changing permissions for: /data/data/com.google.android.apps.maps/app_/testdata from 'rwx------' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.google.android.apps.maps/app_/debug from 'rwx------' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.google.android.apps.maps/app_/cache from 'rwx------' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.google.android.apps.maps/app_/cache/cache_r.m from 'rw-------' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.google.android.apps.maps/databases/LayerInfo-shm from 'rw-r--r--' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.google.android.apps.maps/databases/LayerInfo-wal from 'rw-r--r--' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.google.android.apps.maps/files/DATA_TILE_HISTORY from 'rw-rw----' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.google.android.apps.maps/files/nlp_GlsPlatformKey from 'rw-------' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.google.android.apps.maps/files/nlp_state from 'rw-rw----' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.google.android.apps.maps/files/DATA_Preferences from 'rw-rw----' to 'rwxrwx--x' (771)
Processing (77 of 175): com.google.android.latinimetutorial...
Changing permissions for: /data/data/com.google.android.latinimetutorial from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (78 of 175): com.teamdouche.pacman...
Changing permissions for: /data/data/com.teamdouche.pacman from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (79 of 175): com.pandora.android...
Changing user ownership for: /data/app/com.pandora.android.apk from '0' to '1000'
Changing group ownership for: /data/app/com.pandora.android.apk from '0' to '1000'
Changing permissions for: /data/app/com.pandora.android.apk from 'rw-rw-rw-' to 'rw-r--r--' (644)
Changing permissions for: /data/data/com.pandora.android from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (80 of 175): com.android.providers.settings...
Changing permissions for: /data/data/com.android.providers.settings from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Changing permissions for: /data/data/com.android.providers.settings/databases/settings.db-shm from 'rw-r--r--' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.android.providers.settings/databases/settings.db-wal from 'rw-r--r--' to 'rw-rw----' (660)
Processing (81 of 175): com.android.magicsmoke...
Changing permissions for: /data/data/com.android.magicsmoke from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (82 of 175): com.tmobile.themechooser...
Changing permissions for: /data/data/com.tmobile.themechooser from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (83 of 175): com.android.providers.downloads...
Changing permissions for: /data/data/com.android.providers.downloads from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Changing permissions for: /data/data/com.android.providers.downloads/files/trackball_lights from 'rw-rw-r--' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.android.providers.downloads/databases/downloads.db-shm from 'rw-r--r--' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.android.providers.downloads/databases/downloads.db-wal from 'rw-r--r--' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.android.providers.downloads/app_sslcache/android.clients.google.com.443 from 'rw-------' to 'rwxrwx--x' (771)
Processing (84 of 175): com.usnaviguide.radar_now...
Changing user ownership for: /data/app/com.usnaviguide.radar_now.apk from '0' to '1000'
Changing group ownership for: /data/app/com.usnaviguide.radar_now.apk from '0' to '1000'
Changing permissions for: /data/app/com.usnaviguide.radar_now.apk from 'rw-rw-rw-' to 'rw-r--r--' (644)
Changing permissions for: /data/data/com.usnaviguide.radar_now from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (85 of 175): com.lookout...
Changing permissions for: /data/data/com.lookout from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Changing permissions for: /data/data/com.lookout/lookout.key from 'rw-------' to 'rwxr-xr-x' (755)
Changing permissions for: /data/data/com.lookout/Policy.FLX from 'rw-------' to 'rwxr-xr-x' (755)
Changing permissions for: /data/data/com.lookout/config.txt from 'rw-rw----' to 'rwxr-xr-x' (755)
Changing permissions for: /data/data/com.lookout/DB from 'rwxr-xr-x' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.lookout/DB/system.db from 'rw-rw----' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.lookout/certs from 'rwx------' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.lookout/certs/ca-bundle.crt from 'rw-------' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.lookout/log from 'rwxrwx---' to 'rwxrwx--x' (771)
Processing (86 of 175): net.flixster.android...
Changing permissions for: /data/data/net.flixster.android from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (87 of 175): com.android.server.vpn...
Changing permissions for: /data/data/com.android.server.vpn from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (88 of 175): com.joeykrim.wimaxkeys...
Changing permissions for: /data/data/com.joeykrim.wimaxkeys from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (89 of 175): com.kanokgems.smswidget...
Changing user ownership for: /data/app/com.kanokgems.smswidget.apk from '0' to '1000'
Changing group ownership for: /data/app/com.kanokgems.smswidget.apk from '0' to '1000'
Changing permissions for: /data/app/com.kanokgems.smswidget.apk from 'rw-rw-rw-' to 'rw-r--r--' (644)
Changing permissions for: /data/data/com.kanokgems.smswidget from 'rwxrwxrwx' to 'rwxr-xr-x' (755)
Changing user ownership for: /data/data/com.kanokgems.smswidget from '0' to '10141'
Changing group ownership for: /data/data/com.kanokgems.smswidget from '0' to '10141'
Changing permissions for: /data/data/com.kanokgems.smswidget/shared_prefs from 'rwxrwxrwx' to 'rwxrwx--x' (771)
Changing user ownership for: /data/data/com.kanokgems.smswidget/shared_prefs from '0' to '10141'
Changing group ownership for: /data/data/com.kanokgems.smswidget/shared_prefs from '0' to '10141'
Changing permissions for: /data/data/com.kanokgems.smswidget/shared_prefs/com.kanokgems.smswidget.xml from 'rw-rw-rw-' to 'rw-rw----' (660)
Changing user ownership for: /data/data/com.kanokgems.smswidget/shared_prefs/com.kanokgems.smswidget.xml from '0' to '10141'
Changing group ownership for: /data/data/com.kanokgems.smswidget/shared_prefs/com.kanokgems.smswidget.xml from '0' to '10141'
Changing permissions for: /data/data/com.kanokgems.smswidget/files from 'rwxrwxrwx' to 'rwxrwx--x' (771)
Changing user ownership for: /data/data/com.kanokgems.smswidget/files from '0' to '10141'
Changing group ownership for: /data/data/com.kanokgems.smswidget/files from '0' to '10141'
Changing permissions for: /data/data/com.kanokgems.smswidget/files/77 from 'rw-rw-rw-' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.kanokgems.smswidget/files/79 from 'rw-rw-rw-' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.kanokgems.smswidget/files/186 from 'rw-rw-rw-' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.kanokgems.smswidget/files/25 from 'rw-rw-rw-' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.kanokgems.smswidget/files/26 from 'rw-rw-rw-' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.kanokgems.smswidget/files/87 from 'rw-rw-rw-' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.kanokgems.smswidget/files/185 from 'rw-rw-rw-' to 'rwxrwx--x' (771)
Changing user ownership for: /data/data/com.kanokgems.smswidget/files/77 from '0' to '10141'
Changing user ownership for: /data/data/com.kanokgems.smswidget/files/79 from '0' to '10141'
Changing user ownership for: /data/data/com.kanokgems.smswidget/files/186 from '0' to '10141'
Changing user ownership for: /data/data/com.kanokgems.smswidget/files/25 from '0' to '10141'
Changing user ownership for: /data/data/com.kanokgems.smswidget/files/26 from '0' to '10141'
Changing user ownership for: /data/data/com.kanokgems.smswidget/files/87 from '0' to '10141'
Changing user ownership for: /data/data/com.kanokgems.smswidget/files/185 from '0' to '10141'
Changing group ownership for: /data/data/com.kanokgems.smswidget/files/77 from '0' to '10141'
Changing group ownership for: /data/data/com.kanokgems.smswidget/files/79 from '0' to '10141'
Changing group ownership for: /data/data/com.kanokgems.smswidget/files/186 from '0' to '10141'
Changing group ownership for: /data/data/com.kanokgems.smswidget/files/25 from '0' to '10141'
Changing group ownership for: /data/data/com.kanokgems.smswidget/files/26 from '0' to '10141'
Changing group ownership for: /data/data/com.kanokgems.smswidget/files/87 from '0' to '10141'
Changing group ownership for: /data/data/com.kanokgems.smswidget/files/185 from '0' to '10141'
Processing (90 of 175): com.android.soundrecorder...
Changing permissions for: /data/data/com.android.soundrecorder from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (91 of 175): uk.co.neilandtheresa.Vignette...
Changing user ownership for: /data/app/uk.co.neilandtheresa.Vignette.apk from '0' to '1000'
Changing group ownership for: /data/app/uk.co.neilandtheresa.Vignette.apk from '0' to '1000'
Changing permissions for: /data/app/uk.co.neilandtheresa.Vignette.apk from 'rw-rw-rw-' to 'rw-r--r--' (644)
Changing permissions for: /data/data/uk.co.neilandtheresa.Vignette from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Changing permissions for: /data/data/uk.co.neilandtheresa.Vignette/shared_prefs from 'rwxrwxrwx' to 'rwxrwx--x' (771)
Changing user ownership for: /data/data/uk.co.neilandtheresa.Vignette/shared_prefs from '0' to '10150'
Changing group ownership for: /data/data/uk.co.neilandtheresa.Vignette/shared_prefs from '0' to '10150'
Changing permissions for: /data/data/uk.co.neilandtheresa.Vignette/shared_prefs/Vignette.xml from 'rw-rw-rw-' to 'rw-rw----' (660)
Changing user ownership for: /data/data/uk.co.neilandtheresa.Vignette/shared_prefs/Vignette.xml from '0' to '10150'
Changing group ownership for: /data/data/uk.co.neilandtheresa.Vignette/shared_prefs/Vignette.xml from '0' to '10150'
Changing permissions for: /data/data/uk.co.neilandtheresa.Vignette/files from 'rwxrwxrwx' to 'rwxrwx--x' (771)
Changing user ownership for: /data/data/uk.co.neilandtheresa.Vignette/files from '0' to '10150'
Changing group ownership for: /data/data/uk.co.neilandtheresa.Vignette/files from '0' to '10150'
Changing permissions for: /data/data/uk.co.neilandtheresa.Vignette/files/key from 'rw-rw-rw-' to 'rwxrwx--x' (771)
Changing user ownership for: /data/data/uk.co.neilandtheresa.Vignette/files/key from '0' to '10150'
Changing group ownership for: /data/data/uk.co.neilandtheresa.Vignette/files/key from '0' to '10150'
Processing (92 of 175): com.android.vending.updater...
Changing permissions for: /data/data/com.android.vending.updater from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (93 of 175): com.android.inputmethod.latin...
Changing permissions for: /data/data/com.android.inputmethod.latin from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Changing permissions for: /data/data/com.android.inputmethod.latin/databases/userbigram_dict.db-wal from 'rw-r--r--' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.android.inputmethod.latin/databases/auto_dict.db-wal from 'rw-r--r--' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.android.inputmethod.latin/databases/auto_dict.db-shm from 'rw-r--r--' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.android.inputmethod.latin/databases/userbigram_dict.db-shm from 'rw-r--r--' to 'rw-rw----' (660)
Processing (94 of 175): com.ulocate...
Changing user ownership for: /data/app/com.ulocate.apk from '0' to '1000'
Changing group ownership for: /data/app/com.ulocate.apk from '0' to '1000'
Changing permissions for: /data/app/com.ulocate.apk from 'rw-rw-rw-' to 'rw-r--r--' (644)
Changing permissions for: /data/data/com.ulocate from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Changing permissions for: /data/data/com.ulocate/shared_prefs/WherePublicPreference.xml from 'rw-rw-rw-' to 'rw-rw----' (660)
Processing (95 of 175): com.google.android.onetimeinitializer...
Changing permissions for: /data/data/com.google.android.onetimeinitializer from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (96 of 175): com.osirum.android.sleepmyphone...
Changing permissions for: /data/data/com.osirum.android.sleepmyphone from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (97 of 175): com.androidemu.neslite...
Changing user ownership for: /data/app/com.androidemu.neslite.apk from '0' to '1000'
Changing group ownership for: /data/app/com.androidemu.neslite.apk from '0' to '1000'
Changing permissions for: /data/app/com.androidemu.neslite.apk from 'rw-rw-rw-' to 'rw-r--r--' (644)
Changing permissions for: /data/data/com.androidemu.neslite from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (98 of 175): com.google.android.partnersetup...
Changing permissions for: /data/data/com.google.android.partnersetup from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (99 of 175): com.minder.wallpaper.multiple...
Changing user ownership for: /data/app/com.minder.wallpaper.multiple.apk from '0' to '1000'
Changing group ownership for: /data/app/com.minder.wallpaper.multiple.apk from '0' to '1000'
Changing permissions for: /data/app/com.minder.wallpaper.multiple.apk from 'rw-rw-rw-' to 'rw-r--r--' (644)
Changing permissions for: /data/data/com.minder.wallpaper.multiple from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (100 of 175): com.coremobility.app.vnotes...
Changing user ownership for: /data/app/com.coremobility.app.vnotes.apk from '0' to '1000'
Changing group ownership for: /data/app/com.coremobility.app.vnotes.apk from '0' to '1000'
Changing permissions for: /data/app/com.coremobility.app.vnotes.apk from 'rw-rw-rw-' to 'rw-r--r--' (644)
Changing permissions for: /data/data/com.coremobility.app.vnotes from 'rwxrwxrwx' to 'rwxr-xr-x' (755)
Changing user ownership for: /data/data/com.coremobility.app.vnotes from '0' to '10152'
Changing group ownership for: /data/data/com.coremobility.app.vnotes from '0' to '10152'
Changing permissions for: /data/data/com.coremobility.app.vnotes/files from 'rwxrwxrwx' to 'rwxrwx--x' (771)
Changing user ownership for: /data/data/com.coremobility.app.vnotes/files from '0' to '10152'
Changing group ownership for: /data/data/com.coremobility.app.vnotes/files from '0' to '10152'
Changing permissions for: /data/data/com.coremobility.app.vnotes/files/VN-0003.AMR from 'rw-rw-rw-' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.coremobility.app.vnotes/files/VN-0006.AMR from 'rw-rw-rw-' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.coremobility.app.vnotes/files/VN-0001.AMR from 'rw-rw-rw-' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.coremobility.app.vnotes/files/VN-0002.AMR from 'rw-rw-rw-' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.coremobility.app.vnotes/files/VN-0004.AMR from 'rw-rw-rw-' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.coremobility.app.vnotes/files/VN-0005.AMR from 'rw-rw-rw-' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.coremobility.app.vnotes/files/VN-0009.AMR from 'rw-rw-rw-' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.coremobility.app.vnotes/files/trackball_lights from 'rw-rw-rw-' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.coremobility.app.vnotes/files/VN-0007.AMR from 'rw-rw-rw-' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.coremobility.app.vnotes/files/VN-0008.AMR from 'rw-rw-rw-' to 'rwxrwx--x' (771)
Changing user ownership for: /data/data/com.coremobility.app.vnotes/files/VN-0003.AMR from '0' to '10152'
Changing user ownership for: /data/data/com.coremobility.app.vnotes/files/VN-0006.AMR from '0' to '10152'
Changing user ownership for: /data/data/com.coremobility.app.vnotes/files/VN-0001.AMR from '0' to '10152'
Changing user ownership for: /data/data/com.coremobility.app.vnotes/files/VN-0002.AMR from '0' to '10152'
Changing user ownership for: /data/data/com.coremobility.app.vnotes/files/VN-0004.AMR from '0' to '10152'
Changing user ownership for: /data/data/com.coremobility.app.vnotes/files/VN-0005.AMR from '0' to '10152'
Changing user ownership for: /data/data/com.coremobility.app.vnotes/files/VN-0009.AMR from '0' to '10152'
Changing user ownership for: /data/data/com.coremobility.app.vnfrom '0' to '10132'
Changing user ownership for: /data/data/org.koxx.pure_calendar/files/background_widget_13_land.png from '0' to '10132'
Changing user ownership for: /data/data/org.koxx.pure_calendar/files/background_widget_24_port.png from '0' to '10132'
Changing user ownership for: /data/data/org.koxx.pure_calendar/files/background_widget_45_land.png from '0' to '10132'
Changing user ownership for: /data/data/org.koxx.pure_calendar/files/background_widget_47_land.png from '0' to '10132'
Changing user ownership for: /data/data/org.koxx.pure_calendar/files/background_widget_45_port.png from '0' to '10132'
Changing user ownership for: /data/data/org.koxx.pure_calendar/files/background_widget_109_land.png from '0' to '10132'
Changing group ownership for: /data/data/org.koxx.pure_calendar/files/background_widget_13_port.png from '0' to '10132'
Changing group ownership for: /data/data/org.koxx.pure_calendar/files/background_widget_17_land.png from '0' to '10132'
Changing group ownership for: /data/data/org.koxx.pure_calendar/files/background_widget_17_port.png from '0' to '10132'
Changing group ownership for: /data/data/org.koxx.pure_calendar/files/background_widget_18_land.png from '0' to '10132'
Changing group ownership for: /data/data/org.koxx.pure_calendar/files/background_widget_18_port.png from '0' to '10132'
Changing group ownership for: /data/data/org.koxx.pure_calendar/files/background_widget_20_land.png from '0' to '10132'
Changing group ownership for: /data/data/org.koxx.pure_calendar/files/background_widget_20_port.png from '0' to '10132'
Changing group ownership for: /data/data/org.koxx.pure_calendar/files/background_widget_24_land.png from '0' to '10132'
Changing group ownership for: /data/data/org.koxx.pure_calendar/files/background_widget_47_port.png from '0' to '10132'
Changing group ownership for: /data/data/org.koxx.pure_calendar/files/background_widget_62_land.png from '0' to '10132'
Changing group ownership for: /data/data/org.koxx.pure_calendar/files/background_widget_62_port.png from '0' to '10132'
Changing group ownership for: /data/data/org.koxx.pure_calendar/files/background_widget_109_port.png from '0' to '10132'
Changing group ownership for: /data/data/org.koxx.pure_calendar/files/background_widget_117_land.png from '0' to '10132'
Changing group ownership for: /data/data/org.koxx.pure_calendar/files/background_widget_117_port.png from '0' to '10132'
Changing group ownership for: /data/data/org.koxx.pure_calendar/files/background_widget_13_land.png from '0' to '10132'
Changing group ownership for: /data/data/org.koxx.pure_calendar/files/background_widget_24_port.png from '0' to '10132'
Changing group ownership for: /data/data/org.koxx.pure_calendar/files/background_widget_45_land.png from '0' to '10132'
Changing group ownership for: /data/data/org.koxx.pure_calendar/files/background_widget_47_land.png from '0' to '10132'
Changing group ownership for: /data/data/org.koxx.pure_calendar/files/background_widget_45_port.png from '0' to '10132'
Changing group ownership for: /data/data/org.koxx.pure_calendar/files/background_widget_109_land.png from '0' to '10132'
Changing permissions for: /data/data/org.koxx.pure_calendar/shared_prefs from 'rwxrwxrwx' to 'rwxrwx--x' (771)
Changing user ownership for: /data/data/org.koxx.pure_calendar/shared_prefs from '0' to '10132'
Changing group ownership for: /data/data/org.koxx.pure_calendar/shared_prefs from '0' to '10132'
Changing permissions for: /data/data/org.koxx.pure_calendar/shared_prefs/read_info_panel.xml from 'rw-rw-rw-' to 'rw-rw----' (660)
Changing permissions for: /data/data/org.koxx.pure_calendar/shared_prefs/org.koxx.pure_calendar.xml from 'rw-rw-rw-' to 'rw-rw----' (660)
Changing user ownership for: /data/data/org.koxx.pure_calendar/shared_prefs/read_info_panel.xml from '0' to '10132'
Changing user ownership for: /data/data/org.koxx.pure_calendar/shared_prefs/org.koxx.pure_calendar.xml from '0' to '10132'
Changing group ownership for: /data/data/org.koxx.pure_calendar/shared_prefs/read_info_panel.xml from '0' to '10132'
Changing group ownership for: /data/data/org.koxx.pure_calendar/shared_prefs/org.koxx.pure_calendar.xml from '0' to '10132'
Changing permissions for: /data/data/org.koxx.pure_calendar/databases from 'rwxrwxrwx' to 'rwxrwx--x' (771)
Changing user ownership for: /data/data/org.koxx.pure_calendar/databases from '0' to '10132'
Changing group ownership for: /data/data/org.koxx.pure_calendar/databases from '0' to '10132'
Changing permissions for: /data/data/org.koxx.pure_calendar/databases/database.db from 'rw-rw-rw-' to 'rw-rw----' (660)
Changing user ownership for: /data/data/org.koxx.pure_calendar/databases/database.db from '0' to '10132'
Changing group ownership for: /data/data/org.koxx.pure_calendar/databases/database.db from '0' to '10132'
Processing (16 of 175): com.android.phone...
Changing permissions for: /data/data/com.android.phone from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Changing permissions for: /data/data/com.android.phone/files/blacklist.dat from 'rw-rw----' to 'rwxrwx--x' (771)
Processing (17 of 175): com.aac.cachemate.demo...
Changing user ownership for: /data/app/com.aac.cachemate.demo.apk from '0' to '1000'
Changing group ownership for: /data/app/com.aac.cachemate.demo.apk from '0' to '1000'
Changing permissions for: /data/app/com.aac.cachemate.demo.apk from 'rw-rw-rw-' to 'rw-r--r--' (644)
Changing permissions for: /data/data/com.aac.cachemate.demo from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (18 of 175): com.leo.android.widget...
Changing user ownership for: /data/app/com.leo.android.widget.apk from '0' to '1000'
Changing group ownership for: /data/app/com.leo.android.widget.apk from '0' to '1000'
Changing permissions for: /data/app/com.leo.android.widget.apk from 'rw-rw-rw-' to 'rw-r--r--' (644)
Changing permissions for: /data/data/com.leo.android.widget from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (19 of 175): com.android.calculator2...
Changing permissions for: /data/data/com.android.calculator2 from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (20 of 175): net.cactii.flash2...
Changing permissions for: /data/data/net.cactii.flash2 from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (21 of 175): com.tvonandroid...
Changing user ownership for: /data/app/com.tvonandroid.apk from '0' to '1000'
Changing group ownership for: /data/app/com.tvonandroid.apk from '0' to '1000'
Changing permissions for: /data/app/com.tvonandroid.apk from 'rw-rw-rw-' to 'rw-r--r--' (644)
Changing permissions for: /data/data/com.tvonandroid from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (22 of 175): org.openintents.filemanager...
Changing permissions for: /data/data/org.openintents.filemanager from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (23 of 175): com.android.htmlviewer...
Changing permissions for: /data/data/com.android.htmlviewer from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (24 of 175): com.feasy.game.blocks.magical...
Changing permissions for: /data/data/com.feasy.game.blocks.magical from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (25 of 175): com.bingo.rom_gripper...
Changing user ownership for: /data/app/com.bingo.rom_gripper.apk from '0' to '1000'
Changing group ownership for: /data/app/com.bingo.rom_gripper.apk from '0' to '1000'
Changing permissions for: /data/app/com.bingo.rom_gripper.apk from 'rw-rw-rw-' to 'rw-r--r--' (644)
Changing permissions for: /data/data/com.bingo.rom_gripper from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (26 of 175): com.android.providers.calendar...
Changing permissions for: /data/data/com.android.providers.calendar from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (27 of 175): com.android.bluetooth...
Changing permissions for: /data/data/com.android.bluetooth from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Changing permissions for: /data/data/com.android.bluetooth/databases/btopp.db-wal from 'rw-r--r--' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.android.bluetooth/databases/btopp.db-shm from 'rw-r--r--' to 'rw-rw----' (660)
Processing (28 of 175): com.bel.android.dspmanager...
Changing permissions for: /data/data/com.bel.android.dspmanager from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (29 of 175): com.bigtincan.android.adfree...
Changing user ownership for: /data/app/com.bigtincan.android.adfree.apk from '0' to '1000'
Changing group ownership for: /data/app/com.bigtincan.android.adfree.apk from '0' to '1000'
Changing permissions for: /data/app/com.bigtincan.android.adfree.apk from 'rw-rw-rw-' to 'rw-r--r--' (644)
Changing permissions for: /data/data/com.bigtincan.android.adfree from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (30 of 175): net.bajawa.battery...
Changing user ownership for: /data/app/net.bajawa.battery.apk from '0' to '1000'
Changing group ownership for: /data/app/net.bajawa.battery.apk from '0' to '1000'
Changing permissions for: /data/app/net.bajawa.battery.apk from 'rw-rw-rw-' to 'rw-r--r--' (644)
Changing permissions for: /data/data/net.bajawa.battery from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (31 of 175): com.android.calendar...
Changing permissions for: /data/data/com.android.calendar from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Changing permissions for: /data/data/com.android.calendar/files/trackball_lights from 'rw-rw-r--' to 'rwxrwx--x' (771)
Processing (32 of 175): com.android.browser...
Changing permissions for: /data/data/com.android.browser from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Changing permissions for: /data/data/com.android.browser/app_geolocation/CachedGeoposition.db from 'rw-rw----' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.android.browser/app_geolocation/GeolocationPermissions.db from 'rw-rw----' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.android.browser/app_databases/Databases.db from 'rw-rw----' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.android.browser/app_databases/localstorage from 'rwxrwx---' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.android.browser/app_databases/localstorage/http_www.google.com_0.localstorage from 'rw-r--r--' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.android.browser/app_appcache/ApplicationCache.db from 'rw-rw----' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.android.browser/databases/browser.db-wal from 'rw-r--r--' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.android.browser/databases/webviewCache.db-wal from 'rw-r--r--' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.android.browser/databases/webview.db-wal from 'rw-r--r--' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.android.browser/databases/browser.db-shm from 'rw-r--r--' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.android.browser/databases/webviewCache.db-shm from 'rw-r--r--' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.android.browser/databases/webview.db-shm from 'rw-r--r--' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.android.browser/app_icons/WebpageIcons.db from 'rw-rw----' to 'rwxrwx--x' (771)
Processing (33 of 175): com.android.music...
Changing permissions for: /data/data/com.android.music from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (34 of 175): com.google.tts...
Changing permissions for: /data/data/com.google.tts from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (35 of 175): com.android.providers.downloads.ui...
Changing permissions for: /data/data/com.android.providers.downloads.ui from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (36 of 175): com.verizon.android.wifios...
Changing user ownership for: /data/app-private/com.verizon.android.wifios.apk from '0' to '1000'
Changing group ownership for: /data/app-private/com.verizon.android.wifios.apk from '0' to '10073'
Changing permissions for: /data/app-private/com.verizon.android.wifios.apk from 'rw-rw-rw-' to 'rw-r-----' (640)
Changing permissions for: /data/data/com.verizon.android.wifios from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (37 of 175): android.androidVNC...
Changing user ownership for: /data/app/android.androidVNC.apk from '0' to '1000'
Changing group ownership for: /data/app/android.androidVNC.apk from '0' to '1000'
Changing permissions for: /data/app/android.androidVNC.apk from 'rw-rw-rw-' to 'rw-r--r--' (644)
Changing permissions for: /data/data/android.androidVNC from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (38 of 175): net.zedge.android...
Changing user ownership for: /data/app/net.zedge.android.apk from '0' to '1000'
Changing group ownership for: /data/app/net.zedge.android.apk from '0' to '1000'
Changing permissions for: /data/app/net.zedge.android.apk from 'rw-rw-rw-' to 'rw-r--r--' (644)
Changing permissions for: /data/data/net.zedge.android from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (39 of 175): com.aurorasoftworks.quadrant.ui.standard...
Changing user ownership for: /data/app/com.aurorasoftworks.quadrant.ui.standard.apk from '0' to '1000'
Changing group ownership for: /data/app/com.aurorasoftworks.quadrant.ui.standard.apk from '0' to '1000'
Changing permissions for: /data/app/com.aurorasoftworks.quadrant.ui.standard.apk from 'rw-rw-rw-' to 'rw-r--r--' (644)
Changing permissions for: /data/data/com.aurorasoftworks.quadrant.ui.standard from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (40 of 175): com.android.mms...
Changing permissions for: /data/data/com.android.mms from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Changing permissions for: /data/data/com.android.mms/files/trackball_lights from 'rw-rw-r--' to 'rwxrwx--x' (771)
Processing (41 of 175): com.android.providers.media...
Changing permissions for: /data/data/com.android.providers.media from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (42 of 175): com.cyanogenmod.CMWallpapers...
Changing permissions for: /data/data/com.cyanogenmod.CMWallpapers from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (43 of 175): jp.co.bii.android.app.dskvzr...
Changing user ownership for: /data/app/jp.co.bii.android.app.dskvzr.apk from '0' to '1000'
Changing group ownership for: /data/app/jp.co.bii.android.app.dskvzr.apk from '0' to '1000'
Changing permissions for: /data/app/jp.co.bii.android.app.dskvzr.apk from 'rw-rw-rw-' to 'rw-r--r--' (644)
Changing permissions for: /data/data/jp.co.bii.android.app.dskvzr from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (44 of 175): com.android.certinstaller...
Changing permissions for: /data/data/com.android.certinstaller from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (45 of 175): com.apkf0nn1.penguingolf...
Changing user ownership for: /data/app/com.apkf0nn1.penguingolf.apk from '0' to '1000'
Changing group ownership for: /data/app/com.apkf0nn1.penguingolf.apk from '0' to '1000'
Changing permissions for: /data/app/com.apkf0nn1.penguingolf.apk from 'rw-rw-rw-' to 'rw-r--r--' (644)
Changing permissions for: /data/data/com.apkf0nn1.penguingolf from 'rwxrwxrwx' to 'rwxr-xr-x' (755)
Changing user ownership for: /data/data/com.apkf0nn1.penguingolf from '0' to '10129'
Changing group ownership for: /data/data/com.apkf0nn1.penguingolf from '0' to '10129'
Changing permissions for: /data/data/com.apkf0nn1.penguingolf/shared_prefs from 'rwxrwxrwx' to 'rwxrwx--x' (771)
Changing user ownership for: /data/data/com.apkf0nn1.penguingolf/shared_prefs from '0' to '10129'
Changing group ownership for: /data/data/com.apkf0nn1.penguingolf/shared_prefs from '0' to '10129'
Changing permissions for: /data/data/com.apkf0nn1.penguingolf/shared_prefs/com.apkf0nn1.penguingolf.xml from 'rw-rw-rw-' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.apkf0nn1.penguingolf/shared_prefs/com.apkf0nn1.penguingolf.MCConfig.xml from 'rw-rw-rw-' to 'rw-rw----' (660)
Changing user ownership for: /data/data/com.apkf0nn1.penguingolf/shared_prefs/com.apkf0nn1.penguingolf.xml from '0' to '10129'
Changing user ownership for: /data/data/com.apkf0nn1.penguingolf/shared_prefs/com.apkf0nn1.penguingolf.MCConfig.xml from '0' to '10129'
Changing group ownership for: /data/data/com.apkf0nn1.penguingolf/shared_prefs/com.apkf0nn1.penguingolf.xml from '0' to '10129'
Changing group ownership for: /data/data/com.apkf0nn1.penguingolf/shared_prefs/com.apkf0nn1.penguingolf.MCConfig.xml from '0' to '10129'
Changing permissions for: /data/data/com.apkf0nn1.penguingolf/databases from 'rwxrwxrwx' to 'rwxrwx--x' (771)
Changing user ownership for: /data/data/com.apkf0nn1.penguingolf/databases from '0' to '10129'
Changing group ownership for: /data/data/com.apkf0nn1.penguingolf/databases from '0' to '10129'
Changing permissions for: /data/data/com.apkf0nn1.penguingolf/databases/webview.db from 'rw-rw-rw-' to 'rw-rw----' (660)
Changing user ownership for: /data/data/com.apkf0nn1.penguingolf/databases/webview.db from '0' to '10129'
Changing group ownership for: /data/data/com.apkf0nn1.penguingolf/databases/webview.db from '0' to '10129'
Processing (46 of 175): com.google.android.marvin.kickback...
Changing permissions for: /data/data/com.google.android.marvin.kickback from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (47 of 175): com.cyanogenmod.android.fotakill...
Changing permissions for: /data/data/com.cyanogenmod.android.fotakill from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (48 of 175): org.freecoder.widgets.overclock...
Changing permissions for: /data/data/org.freecoder.widgets.overclock from 'rwxrwxrwx' to 'rwxr-xr-x' (755)
Changing user ownership for: /data/data/org.freecoder.widgets.overclock from '0' to '10125'
Changing group ownership for: /data/data/org.freecoder.widgets.overclock from '0' to '10125'
Changing permissions for: /data/data/org.freecoder.widgets.overclock/shared_prefs from 'rwxrwxrwx' to 'rwxrwx--x' (771)
Changing user ownership for: /data/data/org.freecoder.widgets.overclock/shared_prefs from '0' to '10125'
Changing group ownership for: /data/data/org.freecoder.widgets.overclock/shared_prefs from '0' to '10125'
Changing permissions for: /data/data/org.freecoder.widgets.overclock/shared_prefs/org.freecoder.widgets.overclock_preferences.xml from 'rw-rw-rw-' to 'rw-rw----' (660)
Changing user ownership for: /data/data/org.freecoder.widgets.overclock/shared_prefs/org.freecoder.widgets.overclock_preferences.xml from '0' to '10125'
Changing group ownership for: /data/data/org.freecoder.widgets.overclock/shared_prefs/org.freecoder.widgets.overclock_preferences.xml from '0' to '10125'
Processing (49 of 175): com.android.settings...
Changing permissions for: /data/data/com.android.settings from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Changing permissions for: /data/data/com.android.settings/files from 'rwx------' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.android.settings/files/wallpaper from 'rwxrwx---' to 'rwxrwx--x' (771)
Processing (50 of 175): com.sirma.mobile.bible.android...
Changing permissions for: /data/data/com.sirma.mobile.bible.android from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (51 of 175): com.teslacoilsw.widgetlocker...
Changing permissions for: /data/data/com.teslacoilsw.widgetlocker from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Changing permissions for: /data/data/com.teslacoilsw.widgetlocker/files from 'rwxrwxrwx' to 'rwxrwx--x' (771)
Changing user ownership for: /data/data/com.teslacoilsw.widgetlocker/files from '0' to '10071'
Changing group ownership for: /data/data/com.teslacoilsw.widgetlocker/files from '0' to '10071'
Changing permissions for: /data/data/com.teslacoilsw.widgetlocker/files/wallpaper.png from 'rw-rw-rw-' to 'rwxrwx--x' (771)
Changing user ownership for: /data/data/com.teslacoilsw.widgetlocker/files/wallpaper.png from '0' to '10071'
Changing group ownership for: /data/data/com.teslacoilsw.widgetlocker/files/wallpaper.png from '0' to '10071'
Changing permissions for: /data/data/com.teslacoilsw.widgetlocker/cache/admob_cache from 'rwx------' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.teslacoilsw.widgetlocker/cache/admob_cache/20100709 from 'rwx------' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.teslacoilsw.widgetlocker/databases/widgetslider.db-shm from 'rw-r--r--' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.teslacoilsw.widgetlocker/databases/launcher.db-wal from 'rw-r--r--' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.teslacoilsw.widgetlocker/databases/widgetslider.db-wal from 'rw-r--r--' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.teslacoilsw.widgetlocker/databases/launcher.db-shm from 'rw-r--r--' to 'rw-rw----' (660)
Processing (52 of 175): com.dropbox.android...
Changing user ownership for: /data/app/com.dropbox.android.apk from '0' to '1000'
Changing group ownership for: /data/app/com.dropbox.android.apk from '0' to '1000'
Changing permissions for: /data/app/com.dropbox.android.apk from 'rw-rw-rw-' to 'rw-r--r--' (644)
Changing permissions for: /data/data/com.dropbox.android from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Changing permissions for: /data/data/com.dropbox.android/databases/db.db-wal from 'rw-r--r--' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.dropbox.android/databases/db.db-shm from 'rw-r--r--' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.dropbox.android/files/log.txt from 'rw-------' to 'rwxrwx--x' (771)
Processing (53 of 175): com.C30BY40.onthefly_backup...
Changing user ownership for: /data/app/com.C30BY40.onthefly_backup.apk from '0' to '1000'
Changing group ownership for: /data/app/com.C30BY40.onthefly_backup.apk from '0' to '1000'
Changing permissions for: /data/app/com.C30BY40.onthefly_backup.apk from 'rw-rw-rw-' to 'rw-r--r--' (644)
Changing permissions for: /data/data/com.C30BY40.onthefly_backup from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (54 of 175): com.bw.picme.local...
Changing user ownership for: /data/app/com.bw.picme.local.apk from '0' to '1000'
Changing group ownership for: /data/app/com.bw.picme.local.apk from '0' to '1000'
Changing permissions for: /data/app/com.bw.picme.local.apk from 'rw-rw-rw-' to 'rw-r--r--' (644)
Changing permissions for: /data/data/com.bw.picme.local from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Changing permissions for: /data/data/com.bw.picme.local/bin from 'rwx------' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.bw.picme.local/bin/fb_toggle_access from 'rwxr-xr-x' to 'rwxrwx--x' (771)
Processing (55 of 175): com.google.android.street...
Changing permissions for: /data/data/com.google.android.street from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (56 of 175): com.google.android.apps.genie.geniewidget...
Changing permissions for: /data/data/com.google.android.apps.genie.geniewidget from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Changing permissions for: /data/data/com.google.android.apps.genie.geniewidget/files/DATA_Preferences from 'rw-rw----' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.google.android.apps.genie.geniewidget/files/genie_masfcache from 'rw-rw----' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.google.android.apps.genie.geniewidget/databases/weather.db-shm from 'rw-r--r--' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.google.android.apps.genie.geniewidget/databases/weather.db-wal from 'rw-r--r--' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.google.android.apps.genie.geniewidget/app_news_image_cache from 'rwxrwxr-x' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.google.android.apps.genie.geniewidget/app_news_image_cache/e63c31ed7a713a57 from 'rw-------' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.google.android.apps.genie.geniewidget/app_news_image_cache/e54730513cddf7e8 from 'rw-------' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.google.android.apps.genie.geniewidget/app_news_image_cache/9b5e209b3c7d7a11 from 'rw-------' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.google.android.apps.genie.geniewidget/app_news_image_cache/a35a78b43136408e from 'rw-------' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.google.android.apps.genie.geniewidget/app_news_image_cache/2d5160991d65eb02 from 'rw-------' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.google.android.apps.genie.geniewidget/app_news_image_cache/692db3b54b3cdb17 from 'rw-------' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.google.android.apps.genie.geniewidget/app_news_image_cache/df576bd325312555 from 'rw-------' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.google.android.apps.genie.geniewidget/app_news_image_cache/dad1e5edbabc9370 from 'rw-------' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.google.android.apps.genie.geniewidget/app_news_image_cache/f5360827f8fffc75 from 'rw-------' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.google.android.apps.genie.geniewidget/app_news_image_cache/1ab70cad217271fa from 'rw-------' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.google.android.apps.genie.geniewidget/app_news_image_cache/4b2a50598718cdc9 from 'rw-------' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.google.android.apps.genie.geniewidget/app_news_image_cache/39225900e3882c5c from 'rw-------' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.google.android.apps.genie.geniewidget/app_news_image_cache/1a5fe7e47d02499a from 'rw-------' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.google.android.apps.genie.geniewidget/app_news_image_cache/874e47be91543fd2 from 'rw-------' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.google.android.apps.genie.geniewidget/app_news_image_cache/93fd047b7046966e from 'rw-------' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.google.android.apps.genie.geniewidget/app_news_image_cache/index.txt from 'rw-------' to 'rwxrwx--x%2otes/files/trackball_lights from '0' to '10152'
Changing user ownership for: /data/data/com.coremobility.app.vnotes/files/VN-0007.AMR from '0' to '10152'
Changing user ownership for: /data/data/com.coremobility.app.vnotes/files/VN-0008.AMR from '0' to '10152'
Changing group ownership for: /data/data/com.coremobility.app.vnotes/files/VN-0003.AMR from '0' to '10152'
Changing group ownership for: /data/data/com.coremobility.app.vnotes/files/VN-0006.AMR from '0' to '10152'
Changing group ownership for: /data/data/com.coremobility.app.vnotes/files/VN-0001.AMR from '0' to '10152'
Changing group ownership for: /data/data/com.coremobility.app.vnotes/files/VN-0002.AMR from '0' to '10152'
Changing group ownership for: /data/data/com.coremobility.app.vnotes/files/VN-0004.AMR from '0' to '10152'
Changing group ownership for: /data/data/com.coremobility.app.vnotes/files/VN-0005.AMR from '0' to '10152'
Changing group ownership for: /data/data/com.coremobility.app.vnotes/files/VN-0009.AMR from '0' to '10152'
Changing group ownership for: /data/data/com.coremobility.app.vnotes/files/trackball_lights from '0' to '10152'
Changing group ownership for: /data/data/com.coremobility.app.vnotes/files/VN-0007.AMR from '0' to '10152'
Changing group ownership for: /data/data/com.coremobility.app.vnotes/files/VN-0008.AMR from '0' to '10152'
Changing permissions for: /data/data/com.coremobility.app.vnotes/databases from 'rwxrwxrwx' to 'rwxrwx--x' (771)
Changing user ownership for: /data/data/com.coremobility.app.vnotes/databases from '0' to '10152'
Changing group ownership for: /data/data/com.coremobility.app.vnotes/databases from '0' to '10152'
Changing permissions for: /data/data/com.coremobility.app.vnotes/databases/vnotes_db-wal from 'rw-rw-rw-' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.coremobility.app.vnotes/databases/vnotes_db from 'rw-rw-rw-' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.coremobility.app.vnotes/databases/vnotes_db-shm from 'rw-rw-rw-' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.coremobility.app.vnotes/databases/cm_database-shm from 'rw-rw-rw-' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.coremobility.app.vnotes/databases/cm_database-wal from 'rw-rw-rw-' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.coremobility.app.vnotes/databases/cm_database from 'rw-rw-rw-' to 'rw-rw----' (660)
Changing user ownership for: /data/data/com.coremobility.app.vnotes/databases/vnotes_db from '0' to '10152'
Changing user ownership for: /data/data/com.coremobility.app.vnotes/databases/cm_database from '0' to '10152'
Changing group ownership for: /data/data/com.coremobility.app.vnotes/databases/vnotes_db from '0' to '10152'
Changing group ownership for: /data/data/com.coremobility.app.vnotes/databases/cm_database from '0' to '10152'
Changing permissions for: /data/data/com.coremobility.app.vnotes/shared_prefs from 'rwxrwxrwx' to 'rwxrwx--x' (771)
Changing user ownership for: /data/data/com.coremobility.app.vnotes/shared_prefs from '0' to '10152'
Changing group ownership for: /data/data/com.coremobility.app.vnotes/shared_prefs from '0' to '10152'
Changing permissions for: /data/data/com.coremobility.app.vnotes/shared_prefs/_has_set_default_values.xml from 'rw-rw-rw-' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.coremobility.app.vnotes/shared_prefs/cmconfigstring.xml from 'rw-rw-rw-' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.coremobility.app.vnotes/shared_prefs/cmconfigvalue.xml from 'rw-rw-rw-' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.coremobility.app.vnotes/shared_prefs/com.coremobility.app.vnotes_preferences.xml from 'rw-rw-rw-' to 'rw-rw----' (660)
Changing user ownership for: /data/data/com.coremobility.app.vnotes/shared_prefs/_has_set_default_values.xml from '0' to '10152'
Changing user ownership for: /data/data/com.coremobility.app.vnotes/shared_prefs/cmconfigstring.xml from '0' to '10152'
Changing user ownership for: /data/data/com.coremobility.app.vnotes/shared_prefs/cmconfigvalue.xml from '0' to '10152'
Changing user ownership for: /data/data/com.coremobility.app.vnotes/shared_prefs/com.coremobility.app.vnotes_preferences.xml from '0' to '10152'
Changing group ownership for: /data/data/com.coremobility.app.vnotes/shared_prefs/_has_set_default_values.xml from '0' to '10152'
Changing group ownership for: /data/data/com.coremobility.app.vnotes/shared_prefs/cmconfigstring.xml from '0' to '10152'
Changing group ownership for: /data/data/com.coremobility.app.vnotes/shared_prefs/cmconfigvalue.xml from '0' to '10152'
Changing group ownership for: /data/data/com.coremobility.app.vnotes/shared_prefs/com.coremobility.app.vnotes_preferences.xml from '0' to '10152'
Processing (101 of 175): red.extension.DigitalClockWidget...
Changing user ownership for: /data/app/red.extension.DigitalClockWidget.apk from '0' to '1000'
Changing group ownership for: /data/app/red.extension.DigitalClockWidget.apk from '0' to '1000'
Changing permissions for: /data/app/red.extension.DigitalClockWidget.apk from 'rw-rw-rw-' to 'rw-r--r--' (644)
Changing permissions for: /data/data/red.extension.DigitalClockWidget from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (102 of 175): com.cyanogenmod.stats...
Changing permissions for: /data/data/com.cyanogenmod.stats from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Changing permissions for: /data/data/com.cyanogenmod.stats/files/trackball_lights from 'rw-rw-r--' to 'rwxrwx--x' (771)
Processing (103 of 175): com.android.cardock...
Changing permissions for: /data/data/com.android.cardock from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (104 of 175): com.adobe.reader...
Changing permissions for: /data/data/com.adobe.reader from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (105 of 175): com.dynamixsoftware.printershare.premium...
Changing user ownership for: /data/app/com.dynamixsoftware.printershare.premium.apk from '0' to '1000'
Changing group ownership for: /data/app/com.dynamixsoftware.printershare.premium.apk from '0' to '1000'
Changing permissions for: /data/app/com.dynamixsoftware.printershare.premium.apk from 'rw-rw-rw-' to 'rw-r--r--' (644)
Changing permissions for: /data/data/com.dynamixsoftware.printershare.premium from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (106 of 175): com.google.android.voicesearch...
Changing permissions for: /data/data/com.google.android.voicesearch from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (107 of 175): com.dynamixsoftware.printershare...
Changing permissions for: /data/data/com.dynamixsoftware.printershare from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (108 of 175): com.cyanogenmod.cmparts...
Changing permissions for: /data/data/com.cyanogenmod.cmparts from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (109 of 175): com.palmarysoft.customweatherpro...
Changing user ownership for: /data/app/com.palmarysoft.customweatherpro.apk from '0' to '1000'
Changing group ownership for: /data/app/com.palmarysoft.customweatherpro.apk from '0' to '1000'
Changing permissions for: /data/app/com.palmarysoft.customweatherpro.apk from 'rw-rw-rw-' to 'rw-r--r--' (644)
Changing permissions for: /data/data/com.palmarysoft.customweatherpro from 'rwxrwxrwx' to 'rwxr-xr-x' (755)
Changing user ownership for: /data/data/com.palmarysoft.customweatherpro from '0' to '10126'
Changing group ownership for: /data/data/com.palmarysoft.customweatherpro from '0' to '10126'
Changing permissions for: /data/data/com.palmarysoft.customweatherpro/files from 'rwxrwxrwx' to 'rwxrwx--x' (771)
Changing user ownership for: /data/data/com.palmarysoft.customweatherpro/files from '0' to '10126'
Changing group ownership for: /data/data/com.palmarysoft.customweatherpro/files from '0' to '10126'
Changing permissions for: /data/data/com.palmarysoft.customweatherpro/files/trackball_lights from 'rw-rw-rw-' to 'rwxrwx--x' (771)
Changing user ownership for: /data/data/com.palmarysoft.customweatherpro/files/trackball_lights from '0' to '10126'
Changing group ownership for: /data/data/com.palmarysoft.customweatherpro/files/trackball_lights from '0' to '10126'
Changing permissions for: /data/data/com.palmarysoft.customweatherpro/shared_prefs from 'rwxrwxrwx' to 'rwxrwx--x' (771)
Changing user ownership for: /data/data/com.palmarysoft.customweatherpro/shared_prefs from '0' to '10126'
Changing group ownership for: /data/data/com.palmarysoft.customweatherpro/shared_prefs from '0' to '10126'
Changing permissions for: /data/data/com.palmarysoft.customweatherpro/databases from 'rwxrwxrwx' to 'rwxrwx--x' (771)
Changing user ownership for: /data/data/com.palmarysoft.customweatherpro/databases from '0' to '10126'
Changing group ownership for: /data/data/com.palmarysoft.customweatherpro/databases from '0' to '10126'
Changing permissions for: /data/data/com.palmarysoft.customweatherpro/databases/weather.db from 'rw-rw-rw-' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.palmarysoft.customweatherpro/databases/weather.db-wal from 'rw-rw-rw-' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.palmarysoft.customweatherpro/databases/weather.db-shm from 'rw-rw-rw-' to 'rw-rw----' (660)
Changing user ownership for: /data/data/com.palmarysoft.customweatherpro/databases/weather.db from '0' to '10126'
Changing group ownership for: /data/data/com.palmarysoft.customweatherpro/databases/weather.db from '0' to '10126'
Processing (110 of 175): org.zwanoo.android.speedtest...
Changing user ownership for: /data/app/org.zwanoo.android.speedtest.apk from '0' to '1000'
Changing group ownership for: /data/app/org.zwanoo.android.speedtest.apk from '0' to '1000'
Changing permissions for: /data/app/org.zwanoo.android.speedtest.apk from 'rw-rw-rw-' to 'rw-r--r--' (644)
Changing permissions for: /data/data/org.zwanoo.android.speedtest from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (111 of 175): com.addz.mediascanner...
Changing user ownership for: /data/app/com.addz.mediascanner.apk from '0' to '1000'
Changing group ownership for: /data/app/com.addz.mediascanner.apk from '0' to '1000'
Changing permissions for: /data/app/com.addz.mediascanner.apk from 'rw-rw-rw-' to 'rw-r--r--' (644)
Changing permissions for: /data/data/com.addz.mediascanner from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (112 of 175): com.th.android.widget.SiMiFolder...
Changing user ownership for: /data/app/com.th.android.widget.SiMiFolder.apk from '0' to '1000'
Changing group ownership for: /data/app/com.th.android.widget.SiMiFolder.apk from '0' to '1000'
Changing permissions for: /data/app/com.th.android.widget.SiMiFolder.apk from 'rw-rw-rw-' to 'rw-r--r--' (644)
Changing permissions for: /data/data/com.th.android.widget.SiMiFolder from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Changing permissions for: /data/data/com.th.android.widget.SiMiFolder/databases/SiMiFolder.db-shm from 'rw-r--r--' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.th.android.widget.SiMiFolder/databases/SiMiFolder.db-wal from 'rw-r--r--' to 'rw-rw----' (660)
Processing (113 of 175): com.google.android.feedback...
Changing permissions for: /data/data/com.google.android.feedback from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (114 of 175): com.shazam.android...
Changing permissions for: /data/data/com.shazam.android from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (115 of 175): com.google.android.talk...
Changing permissions for: /data/data/com.google.android.talk from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (116 of 175): com.slacker.radio...
Changing user ownership for: /data/app/com.slacker.radio.apk from '0' to '1000'
Changing group ownership for: /data/app/com.slacker.radio.apk from '0' to '1000'
Changing permissions for: /data/app/com.slacker.radio.apk from 'rw-rw-rw-' to 'rw-r--r--' (644)
Changing permissions for: /data/data/com.slacker.radio from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (117 of 175): net.launchpad.thermometer...
Changing user ownership for: /data/app/net.launchpad.thermometer.apk from '0' to '1000'
Changing group ownership for: /data/app/net.launchpad.thermometer.apk from '0' to '1000'
Changing permissions for: /data/app/net.launchpad.thermometer.apk from 'rw-rw-rw-' to 'rw-r--r--' (644)
Changing permissions for: /data/data/net.launchpad.thermometer from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (118 of 175): com.cooliris.media...
Changing permissions for: /data/data/com.cooliris.media from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Changing permissions for: /data/data/com.cooliris.media/databases/picasa.db-wal from 'rw-r--r--' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.cooliris.media/databases/picasa.db-shm from 'rw-r--r--' to 'rw-rw----' (660)
Processing (119 of 175): jp.tom016.flipf...
Changing user ownership for: /data/app-private/jp.tom016.flipf.apk from '0' to '1000'
Changing group ownership for: /data/app-private/jp.tom016.flipf.apk from '0' to '10116'
Changing permissions for: /data/app-private/jp.tom016.flipf.apk from 'rw-rw-rw-' to 'rw-r-----' (640)
Changing permissions for: /data/data/jp.tom016.flipf from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (120 of 175): com.studydroid.flashcards.free...
Changing user ownership for: /data/app/com.studydroid.flashcards.free.apk from '0' to '1000'
Changing group ownership for: /data/app/com.studydroid.flashcards.free.apk from '0' to '1000'
Changing permissions for: /data/app/com.studydroid.flashcards.free.apk from 'rw-rw-rw-' to 'rw-r--r--' (644)
Changing permissions for: /data/data/com.studydroid.flashcards.free from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (121 of 175): com.koushikdutta.rommanager...
Changing permissions for: /data/data/com.koushikdutta.rommanager from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Changing permissions for: /data/data/com.koushikdutta.rommanager/files/rommanager.sh from 'rw-rw----' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.koushikdutta.rommanager/files/test_ad.png from 'rwxr-xr-x' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.koushikdutta.rommanager/files/tune2fs from 'rwxr-xr-x' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.koushikdutta.rommanager/files/tegra_flash_image from 'rwxr-xr-x' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.koushikdutta.rommanager/files/sdparted from 'rwxr-xr-x' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.koushikdutta.rommanager/files/reboot from 'rwxr-xr-x' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.koushikdutta.rommanager/files/preparepartition.sh from 'rwxr-xr-x' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.koushikdutta.rommanager/files/parted from 'rwxr-xr-x' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.koushikdutta.rommanager/files/flash_image from 'rwxr-xr-x' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.koushikdutta.rommanager/files/fix_permissions from 'rwxr-xr-x' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.koushikdutta.rommanager/files/erase_image from 'rwxr-xr-x' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.koushikdutta.rommanager/files/e2fsck from 'rwxr-xr-x' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.koushikdutta.rommanager/files/dump_image from 'rwxr-xr-x' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.koushikdutta.rommanager/files/dopartition.sh from 'rwxr-xr-x' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.koushikdutta.rommanager/databases/settings.db-wal from 'rw-r--r--' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.koushikdutta.rommanager/databases/settings.db-shm from 'rw-r--r--' to 'rw-rw----' (660)
Processing (122 of 175): com.android.providers.userdictionary...
Changing permissions for: /data/data/com.android.providers.userdictionary from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Changing permissions for: /data/data/com.android.providers.userdictionary/databases/user_dict.db-wal from 'rw-r--r--' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.android.providers.userdictionary/databases/user_dict.db-shm from 'rw-r--r--' to 'rw-rw----' (660)
Processing (123 of 175): com.quoord.tapatalkxda.activity...
Changing user ownership for: /data/app/com.quoord.tapatalkxda.activity.apk from '0' to '1000'
Changing group ownership for: /data/app/com.quoord.tapatalkxda.activity.apk from '0' to '1000'
Changing permissions for: /data/app/com.quoord.tapatalkxda.activity.apk from 'rw-rw-rw-' to 'rw-r--r--' (644)
Changing permissions for: /data/data/com.quoord.tapatalkxda.activity from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (124 of 175): com.android.setupwizard...
Changing permissions for: /data/data/com.android.setupwizard from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (125 of 175): org.mhgames.jewels...
Changing permissions for: /data/data/org.mhgames.jewels from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (126 of 175): android.tts...
Changing permissions for: /data/data/android.tts from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (127 of 175): com.fede.launcher...
Changing user ownership for: /data/app/com.fede.launcher.apk from '0' to '1000'
Changing group ownership for: /data/app/com.fede.launcher.apk from '0' to '1000'
Changing permissions for: /data/app/com.fede.launcher.apk from 'rw-rw-rw-' to 'rw-r--r--' (644)
Changing permissions for: /data/data/com.fede.launcher from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Changing permissions for: /data/data/com.fede.launcher/.nomedia from 'rw-------' to 'rwxr-xr-x' (755)
Changing permissions for: /data/data/com.fede.launcher/databases from 'rwx------' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.fede.launcher/databases/webviewCache.db-wal from 'rw-r--r--' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.fede.launcher/databases/webviewCache.db-shm from 'rw-r--r--' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.fede.launcher/databases/webview.db-wal from 'rw-r--r--' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.fede.launcher/databases/facebook.db-wal from 'rw-r--r--' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.fede.launcher/databases/webview.db-shm from 'rw-r--r--' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.fede.launcher/databases/launcher.db-wal from 'rw-------' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.fede.launcher/databases/facebook.db-shm from 'rw-r--r--' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.fede.launcher/databases/launcher.db-shm from 'rw-------' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.fede.launcher/files from 'rwx------' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.fede.launcher/files/dock_custom_background_portrait.png from 'rw-rw----' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.fede.launcher/files/dock_custom_background_landscape.png from 'rw-rw----' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.fede.launcher/files/launcher.preferences from 'rw-rw----' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.fede.launcher/shared_prefs from 'rwx------' to 'rwxrwx--x' (771)
Processing (128 of 175): com.edburnette.fps2d...
Changing user ownership for: /data/app/com.edburnette.fps2d.apk from '0' to '1000'
Changing group ownership for: /data/app/com.edburnette.fps2d.apk from '0' to '1000'
Changing permissions for: /data/app/com.edburnette.fps2d.apk from 'rw-rw-rw-' to 'rw-r--r--' (644)
Changing permissions for: /data/data/com.edburnette.fps2d from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (129 of 175): com.google.android.stardroid...
Changing permissions for: /data/data/com.google.android.stardroid from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (130 of 175): coveroid.wallpapers...
Changing user ownership for: /data/app/coveroid.wallpapers.apk from '0' to '1000'
Changing group ownership for: /data/app/coveroid.wallpapers.apk from '0' to '1000'
Changing permissions for: /data/app/coveroid.wallpapers.apk from 'rw-rw-rw-' to 'rw-r--r--' (644)
Changing permissions for: /data/data/coveroid.wallpapers from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (131 of 175): com.vp.alarmClockPlusDock...
Changing permissions for: /data/data/com.vp.alarmClockPlusDock from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Changing permissions for: /data/data/com.vp.alarmClockPlusDock/databases/widgId.db-wal from 'rw-r--r--' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.vp.alarmClockPlusDock/databases/widgId.db-shm from 'rw-r--r--' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.vp.alarmClockPlusDock/databases/alarms.db-wal from 'rw-r--r--' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.vp.alarmClockPlusDock/databases/alarms.db-shm from 'rw-r--r--' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.vp.alarmClockPlusDock/files/trackball_lights from 'rw-rw-r--' to 'rwxrwx--x' (771)
Processing (132 of 175): com.gameloft.android.GAND.GloftUNO.uno...
Changing user ownership for: /data/app/com.gameloft.android.GAND.GloftUNO.uno.apk from '0' to '1000'
Changing group ownership for: /data/app/com.gameloft.android.GAND.GloftUNO.uno.apk from '0' to '1000'
Changing permissions for: /data/app/com.gameloft.android.GAND.GloftUNO.uno.apk from 'rw-rw-rw-' to 'rw-r--r--' (644)
Changing permissions for: /data/data/com.gameloft.android.GAND.GloftUNO.uno from 'rwxrwxrwx' to 'rwxr-xr-x' (755)
Changing user ownership for: /data/data/com.gameloft.android.GAND.GloftUNO.uno from '0' to '10149'
Changing group ownership for: /data/data/com.gameloft.android.GAND.GloftUNO.uno from '0' to '10149'
Processing (133 of 175): com.google.android.syncadapters.calendar...
Changing permissions for: /data/data/com.google.android.syncadapters.calendar from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (134 of 175): android.tether...
Changing user ownership for: /data/app/android.tether.apk from '0' to '1000'
Changing group ownership for: /data/app/android.tether.apk from '0' to '1000'
Changing permissions for: /data/app/android.tether.apk from 'rw-rw-rw-' to 'rw-r--r--' (644)
Changing permissions for: /data/data/android.tether from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Changing permissions for: /data/data/android.tether/files from 'rwxrwxrwx' to 'rwxrwx--x' (771)
Changing user ownership for: /data/data/android.tether/files from '0' to '10153'
Changing group ownership for: /data/data/android.tether/files from '0' to '10153'
Changing permissions for: /data/data/android.tether/files/trackball_lights from 'rw-rw-rw-' to 'rwxrwx--x' (771)
Changing user ownership for: /data/data/android.tether/files/trackball_lights from '0' to '10153'
Changing group ownership for: /data/data/android.tether/files/trackball_lights from '0' to '10153'
Changing permissions for: /data/data/android.tether/conf from 'rwxrwxrwx' to 'rwxrwx--x' (771)
Changing user ownership for: /data/data/android.tether/conf from '0' to '10153'
Changing group ownership for: /data/data/android.tether/conf from '0' to '10153'
Changing permissions for: /data/data/android.tether/conf/whitelist_mac.conf from 'rw-rw-rw-' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/android.tether/conf/dnsmasq.conf from 'rw-rw-rw-' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/android.tether/conf/resolv.conf from 'rw-rw-rw-' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/android.tether/conf/tether.conf from 'rw-rw-rw-' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/android.tether/conf/tether.edify from 'rw-rw-rw-' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/android.tether/conf/tiwlan.ini from 'rw-rw-rw-' to 'rwxrwx--x' (771)
Changing user ownership for: /data/data/android.tether/conf/whitelist_mac.conf from '0' to '10153'
Changing user ownership for: /data/data/android.tether/conf/dnsmasq.conf from '0' to '10153'
Changing user ownership for: /data/data/android.tether/conf/resolv.conf from '0' to '10153'
Changing user ownership for: /data/data/android.tether/conf/tether.conf from '0' to '10153'
Changing user ownership for: /data/data/android.tether/conf/tether.edify from '0' to '10153'
Changing user ownership for: /data/data/android.tether/conf/tiwlan.ini from '0' to '10153'
Changing group ownership for: /data/data/android.tether/conf/whitelist_mac.conf from '0' to '10153'
Changing group ownership for: /data/data/android.tether/conf/dnsmasq.conf from '0' to '10153'
Changing group ownership for: /data/data/android.tether/conf/resolv.conf from '0' to '10153'
Changing group ownership for: /data/data/android.tether/conf/tether.conf from '0' to '10153'
Changing group ownership for: /data/data/android.tether/conf/tether.edify from '0' to '10153'
Changing group ownership for: /data/data/android.tether/conf/tiwlan.ini from '0' to '10153'
Changing permissions for: /data/data/android.tether/var from 'rwxrwxrwx' to 'rwxrwx--x' (771)
Changing user ownership for: /data/data/android.tether/var from '0' to '10153'
Changing group ownership for: /data/data/android.tether/var from '0' to '10153'
Changing permissions for: /data/data/android.tether/var/tether.log from 'rw-rw-rw-' to 'rwxrwx--x' (771)
Changing user ownership for: /data/data/android.tether/var/tether.log from '0' to '10153'
Changing group ownership for: /data/data/android.tether/var/tether.log from '0' to '10153'
Changing permissions for: /data/data/android.tether/shared_prefs from 'rwxrwxrwx' to 'rwxrwx--x' (771)
Changing user ownership for: /data/data/android.tether/shared_prefs from '0' to '10153'
Changing group ownership for: /data/data/android.tether/shared_prefs from '0' to '10153'
Changing permissions for: /data/data/android.tether/shared_prefs/android.tether_preferences.xml from 'rw-rw-rw-' to 'rw-rw----' (660)
Changing user ownership for: /data/data/android.tether/shared_prefs/android.tether_preferences.xml from '0' to '10153'
Changing group ownership for: /data/data/android.tether/shared_prefs/android.tether_preferences.xml from '0' to '10153'
Changing permissions for: /data/data/android.tether/bin from 'rwxrwxrwx' to 'rwxrwx--x' (771)
Changing user ownership for: /data/data/android.tether/bin from '0' to '10153'
Changing group ownership for: /data/data/android.tether/bin from '0' to '10153'
Changing permissions for: /data/data/android.tether/bin/iptables from 'rw-rw-rw-' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/android.tether/bin/blue-down.sh from 'rw-rw-rw-' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/android.tether/bin/blue-up.sh from 'rw-rw-rw-' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/android.tether/bin/dnsmasq from 'rw-rw-rw-' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/android.tether/bin/iwconfig from 'rw-rw-rw-' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/android.tether/bin/pand from 'rw-rw-rw-' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/android.tether/bin/tether from 'rw-rw-rw-' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/android.tether/bin/ultra_bcm_config from 'rw-rw-rw-' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/android.tether/bin/ifconfig from 'rw-rw-rw-' to 'rwxrwx--x' (771)
Changing user ownership for: /data/data/android.tether/bin/iptables from '0' to '10153'
Changing user ownership for: /data/data/android.tether/bin/blue-down.sh from '0' to '10153'
Changing user ownership for: /data/data/android.tether/bin/blue-up.sh from '0' to '10153'
Changing user ownership for: /data/data/android.tether/bin/dnsmasq from '0' to '10153'
Changing user ownership for: /data/data/android.tether/bin/iwconfig from '0' to '10153'
Changing user ownership for: /data/data/android.tether/bin/pand from '0' to '10153'
Changing user ownership for: /data/data/android.tether/bin/tether from '0' to '10153'
Changing user ownership for: /data/data/android.tether/bin/ultra_bcm_config from '0' to '10153'
Changing user ownership for: /data/data/android.tether/bin/ifconfig from '0' to '10153'
Changing group ownership for: /data/data/android.tether/bin/iptables from '0' to '10153'
Changing group ownership for: /data/data/android.tether/bin/blue-down.sh from '0' to '10153'
Changing group ownership for: /data/data/android.tether/bin/blue-up.sh from '0' to '10153'
Changing group ownership for: /data/data/android.tether/bin/dnsmasq from '0' to '10153'
Changing group ownership for: /data/data/android.tether/bin/iwconfig from '0' to '10153'
Changing group ownership for: /data/data/android.tether/bin/pand from '0' to '10153'
Changing group ownership for: /data/data/android.tether/bin/tether from '0' to '10153'
Changing group ownership for: /data/data/android.tether/bin/ultra_bcm_config from '0' to '10153'
Changing group ownership for: /data/data/android.tether/bin/ifconfig from '0' to '10153'
Processing (135 of 175): com.android.providers.contacts...
Changing permissions for: /data/data/com.android.providers.contacts from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (136 of 175): com.google.zxing.client.android...
Changing user ownership for: /data/app/com.google.zxing.client.android.apk from '0' to '1000'
Changing group ownership for: /data/app/com.google.zxing.client.android.apk from '0' to '1000'
Changing permissions for: /data/app/com.google.zxing.client.android.apk from 'rw-rw-rw-' to 'rw-r--r--' (644)
Changing permissions for: /data/data/com.google.zxing.client.android from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (137 of 175): since2006.apps.pandora...
Changing user ownership for: /data/app/since2006.apps.pandora.apk from '0' to '1000'
Changing group ownership for: /data/app/since2006.apps.pandora.apk from '0' to '1000'
Changing permissions for: /data/app/since2006.apps.pandora.apk from 'rw-rw-rw-' to 'rw-r--r--' (644)
Changing permissions for: /data/data/since2006.apps.pandora from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (138 of 175): com.beansoft.lcd_density_changer...
Changing user ownership for: /data/app/com.beansoft.lcd_density_changer.apk from '0' to '1000'
Changing group ownership for: /data/app/com.beansoft.lcd_density_changer.apk from '0' to '1000'
Changing permissions for: /data/app/com.beansoft.lcd_density_changer.apk from 'rw-rw-rw-' to 'rw-r--r--' (644)
Changing permissions for: /data/data/com.beansoft.lcd_density_changer from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Changing permissions for: /data/data/com.beansoft.lcd_density_changer/files from 'rwx------' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.beansoft.lcd_density_changer/files/build.prop from 'rw-------' to 'rwxrwx--x' (771)
Processing (139 of 175): ccc71.bmw...
Changing user ownership for: /data/app/ccc71.bmw.apk from '0' to '1000'
Changing group ownership for: /data/app/ccc71.bmw.apk from '0' to '1000'
Changing permissions for: /data/app/ccc71.bmw.apk from 'rw-rw-rw-' to 'rw-r--r--' (644)
Changing permissions for: /data/data/ccc71.bmw from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (140 of 175): com.android.protips...
Changing permissions for: /data/data/com.android.protips from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (141 of 175): com.google.android.apps.uploader...
Changing permissions for: /data/data/com.google.android.apps.uploader from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (142 of 175): com.android.providers.applications...
Changing permissions for: /data/data/com.android.providers.applications from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (143 of 175): com.android.fm...
Changing permissions for: /data/data/com.android.fm from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (144 of 175): com.theswirlingbrain.speed...
Changing user ownership for: /data/app-private/com.theswirlingbrain.speed.apk from '0' to '1000'
Changing group ownership for: /data/app-private/com.theswirlingbrain.speed.apk from '0' to '10077'
Changing permissions for: /data/app-private/com.theswirlingbrain.speed.apk from 'rw-rw-rw-' to 'rw-r-----' (640)
Changing permissions for: /data/data/com.theswirlingbrain.speed from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (145 of 175): com.mobisystems.editor.office_with_reg...
Changing user ownership for: /data/app/com.mobisystems.editor.office_with_reg.apk from '0' to '1000'
Changing group ownership for: /data/app/com.mobisystems.editor.office_with_reg.apk from '0' to '1000'
Changing permissions for: /data/app/com.mobisystems.editor.office_with_reg.apk from 'rw-rw-rw-' to 'rw-r--r--' (644)
Changing permissions for: /data/data/com.mobisystems.editor.office_with_reg from 'rwxrwxrwx' to 'rwxr-xr-x' (755)
Changing user ownership for: /data/data/com.mobisystems.editor.office_with_reg from '0' to '10124'
Changing group ownership for: /data/data/com.mobisystems.editor.office_with_reg from '0' to '10124'
Changing permissions for: /data/data/com.mobisystems.editor.office_with_reg/shared_prefs from 'rwxrwxrwx' to 'rwxrwx--x' (771)
Changing user ownership for: /data/data/com.mobisystems.editor.office_with_reg/shared_prefs from '0' to '10124'
Changing group ownership for: /data/data/com.mobisystems.editor.office_with_reg/shared_prefs from '0' to '10124'
Changing permissions for: /data/data/com.mobisystems.editor.office_with_reg/shared_prefs/com.mobisystems.office.rs.xml from 'rw-rw-rw-' to 'rw-rw----' (660)
Changing user ownership for: /data/data/com.mobisystems.editor.office_with_reg/shared_prefs/com.mobisystems.office.rs.xml from '0' to '10124'
Changing group ownership for: /data/data/com.mobisystems.editor.office_with_reg/shared_prefs/com.mobisystems.office.rs.xml from '0' to '10124'
Changing permissions for: /data/data/com.mobisystems.editor.office_with_reg/databases from 'rwxrwxrwx' to 'rwxrwx--x' (771)
Changing user ownership for: /data/data/com.mobisystems.editor.office_with_reg/databases from '0' to '10124'
Changing group ownership for: /data/data/com.mobisystems.editor.office_with_reg/databases from '0' to '10124'
Changing permissions for: /data/data/com.mobisystems.editor.office_with_reg/databases/encoding.db from 'rw-rw-rw-' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.mobisystems.editor.office_with_reg/databases/recovery.db from 'rw-rw-rw-' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.mobisystems.editor.office_with_reg/databases/recovery.db-wal from 'rw-rw-rw-' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.mobisystems.editor.office_with_reg/databases/recovery.db-shm from 'rw-rw-rw-' to 'rw-rw----' (660)
Changing user ownership for: /data/data/com.mobisystems.editor.office_with_reg/databases/encoding.db from '0' to '10124'
Changing user ownership for: /data/data/com.mobisystems.editor.office_with_reg/databases/recovery.db from '0' to '10124'
Changing group ownership for: /data/data/com.mobisystems.editor.office_with_reg/databases/encoding.db from '0' to '10124'
Changing group ownership for: /data/data/com.mobisystems.editor.office_with_reg/databases/recovery.db from '0' to '10124'
Processing (146 of 175): net.hubalek.android.makeyourclock...
Changing user ownership for: /data/app/net.hubalek.android.makeyourclock.apk from '0' to '1000'
Changing group ownership for: /data/app/net.hubalek.android.makeyourclock.apk from '0' to '1000'
Changing permissions for: /data/app/net.hubalek.android.makeyourclock.apk from 'rw-rw-rw-' to 'rw-r--r--' (644)
Changing permissions for: /data/data/net.hubalek.android.makeyourclock from 'rwxrwxrwx' to 'rwxr-xr-x' (755)
Changing user ownership for: /data/data/net.hubalek.android.makeyourclock from '0' to '10119'
Changing group ownership for: /data/data/net.hubalek.android.makeyourclock from '0' to '10119'
Changing permissions for: /data/data/net.hubalek.android.makeyourclock/shared_prefs from 'rwxrwxrwx' to 'rwxrwx--x' (771)
Changing user ownership for: /data/data/net.hubalek.android.makeyourclock/shared_prefs from '0' to '10119'
Changing group ownership for: /data/data/net.hubalek.android.makeyourclock/shared_prefs from '0' to '10119'
Changing permissions for: /data/data/net.hubalek.android.makeyourclock/shared_prefs/Editor.xml from 'rw-rw-rw-' to 'rw-rw----' (660)
Changing permissions for: /data/data/net.hubalek.android.makeyourclock/shared_prefs/MakeYourClock.Prefs.xml from 'rw-rw-rw-' to 'rw-rw----' (660)
Changing permissions for: /data/data/net.hubalek.android.makeyourclock/shared_prefs/net.hubalek.android.makeyourclock_preferences.xml from 'rw-rw-rw-' to 'rw-rw----' (660)
Changing user ownership for: /data/data/net.hubalek.android.makeyourclock/shared_prefs/Editor.xml from '0' to '10119'
Changing user ownership for: /data/data/net.hubalek.android.makeyourclock/shared_prefs/MakeYourClock.Prefs.xml from '0' to '10119'
Changing user ownership for: /data/data/net.hubalek.android.makeyourclock/shared_prefs/net.hubalek.android.makeyourclock_preferences.xml from '0' to '10119'
Changing group ownership for: /data/data/net.hubalek.android.makeyourclock/shared_prefs/Editor.xml from '0' to '10119'
Changing group ownership for: /data/data/net.hubalek.android.makeyourclock/shared_prefs/MakeYourClock.Prefs.xml from '0' to '10119'
Changing group ownership for: /data/data/net.hubalek.android.makeyourclock/shared_prefs/net.hubalek.android.makeyourclock_preferences.xml from '0' to '10119'
Processing (147 of 175): com.android.vending...
Changing permissions for: /data/data/com.android.vending from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Changing permissions for: /data/data/com.android.vending/files/trackball_lights from 'rw-rw-r--' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.android.vending/app_sslcache/android.clients.google.com.443 from 'rw-------' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.android.vending/databases/webviewCache.db-wal from 'rw-r--r--' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.android.vending/databases/webview.db-shm from 'rw-r--r--' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.android.vending/databases/webview.db-wal from 'rw-r--r--' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.android.vending/databases/billing4.db-wal from 'rw-r--r--' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.android.vending/databases/webviewCache.db-shm from 'rw-r--r--' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.android.vending/databases/assets14.db from 'rw-rw-rw-' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.android.vending/databases/billing4.db-shm from 'rw-r--r--' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.android.vending/databases/assets14.db-shm from 'rw-r--r--' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.android.vending/databases/assets14.db-wal from 'rw-r--r--' to 'rw-rw----' (660)
Changing user ownership for: /data/data/com.android.vending/databases/assets14.db from '0' to '10058'
Changing group ownership for: /data/data/com.android.vending/databases/assets14.db from '0' to '10058'
Processing (148 of 175): com.tmobile.thememanager...
Changing permissions for: /data/data/com.tmobile.thememanager from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Changing permissions for: /data/data/com.tmobile.thememanager/databases/theme_item.db-wal from 'rw-r--r--' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.tmobile.thememanager/databases/theme_item.db-shm from 'rw-r--r--' to 'rw-rw----' (660)
Processing (149 of 175): com.speedsoftware.rootexplorer...
Changing user ownership for: /data/app/com.speedsoftware.rootexplorer.apk from '0' to '1000'
Changing group ownership for: /data/app/com.speedsoftware.rootexplorer.apk from '0' to '1000'
Changing permissions for: /data/app/com.speedsoftware.rootexplorer.apk from 'rw-rw-rw-' to 'rw-r--r--' (644)
Changing permissions for: /data/data/com.speedsoftware.rootexplorer from 'rwxrwxrwx' to 'rwxr-xr-x' (755)
Changing user ownership for: /data/data/com.speedsoftware.rootexplorer from '0' to '10138'
Changing group ownership for: /data/data/com.speedsoftware.rootexplorer from '0' to '10138'
Changing permissions for: /data/data/com.speedsoftware.rootexplorer/databases from 'rwxrwxrwx' to 'rwxrwx--x' (771)
Changing user ownership for: /data/data/com.speedsoftware.rootexplorer/databases from '0' to '10138'
Changing group ownership for: /data/data/com.speedsoftware.rootexplorer/databases from '0' to '10138'
Changing permissions for: /data/data/com.speedsoftware.rootexplorer/databases/explorer.db from 'rw-rw-rw-' to 'rw-rw----' (660)
Changing user ownership for: /data/data/com.speedsoftware.rootexplorer/databases/explorer.db from '0' to '10138'
Changing group ownership for: /data/data/com.speedsoftware.rootexplorer/databases/explorer.db from '0' to '10138'
Processing (150 of 175): ix.com.android.VirtualRecorder...
Changing user ownership for: /data/app/ix.com.android.VirtualRecorder.apk from '0' to '1000'
Changing group ownership for: /data/app/ix.com.android.VirtualRecorder.apk from '0' to '1000'
Changing permissions for: /data/app/ix.com.android.VirtualRecorder.apk from 'rw-rw-rw-' to 'rw-r--r--' (644)
Changing permissions for: /data/data/ix.com.android.VirtualRecorder from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (151 of 175): com.android.systemui...
Changing permissions for: /data/data/com.android.systemui from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Changing permissions for: /data/data/com.android.systemui/files/trackball_lights from 'rw-rw-r--' to 'rwxrwx--x' (771)
Processing (152 of 175): com.tmobile.theme.Androidian...
Changing permissions for: /data/data/com.tmobile.theme.Androidian from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (153 of 175): com.electricsheep.asi...
Changing permissions for: /data/data/com.electricsheep.asi from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (154 of 175): com.appspot.swisscodemonkeys.apps...
Changing permissions for: /data/data/com.appspot.swisscodemonkeys.apps from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Changing permissions for: /data/data/com.appspot.swisscodemonkeys.apps/databases/apps.db-shm from 'rw-r--r--' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.appspot.swisscodemonkeys.apps/databases/apps.db-wal from 'rw-r--r--' to 'rw-rw----' (660)
Processing (155 of 175): com.google.android.gm...
Changing permissions for: /data/data/com.google.android.gm from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Changing permissions for: /data/data/com.google.android.gm/files/trackball_lights from 'rw-rw-r--' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.google.android.gm/cache/download from 'rwx------' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.google.android.gm/app_sslcache/android.clients.google.com.443 from 'rw-------' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.google.android.gm/databases/gmail.db-wal from 'rw-r--r--' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.google.android.gm/databases/webview.db-wal from 'rw-r--r--' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.google.android.gm/databases/webviewCache.db-shm from 'rw-r--r--' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.google.android.gm/databases/webview.db-shm from 'rw-r--r--' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.google.android.gm/databases/mailstore.cory.faylor@gmail.com.db-wal from 'rw-r--r--' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.google.android.gm/databases/mailstore.cory.faylor@gmail.com.db-shm from 'rw-r--r--' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.google.android.gm/databases/webviewCache.db-wal from 'rw-r--r--' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.google.android.gm/databases/suggestions.db-wal from 'rw-r--r--' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.google.android.gm/databases/suggestions.db-shm from 'rw-r--r--' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.google.android.gm/databases/gmail.db-shm from 'rw-r--r--' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.google.android.gm/databases/downloads.db-wal from 'rw-r--r--' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.google.android.gm/databases/downloads.db-shm from 'rw-r--r--' to 'rw-rw----' (660)
Processing (156 of 175): com.android.wallpaper...
Changing permissions for: /data/data/com.android.wallpaper from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (157 of 175): com.android.camera...
Changing permissions for: /data/data/com.android.camera from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (158 of 175): com.estrongs.android.pop...
Changing permissions for: /data/data/com.estrongs.android.pop from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Changing permissions for: /data/data/com.estrongs.android.pop/cache/.thumbnails from 'rwx------' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.estrongs.android.pop/cache/.apps from 'rwx------' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.estrongs.android.pop/files/trackball_lights from 'rw-rw-r--' to 'rwxrwx--x' (771)
Processing (159 of 175): com.noshufou.android.su...
Changing permissions for: /data/data/com.noshufou.android.su from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (160 of 175): com.google.android.youtube...
Changing permissions for: /data/data/com.google.android.youtube from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Changing permissions for: /data/data/com.google.android.youtube/files/DATA_Preferences from 'rw-rw----' to 'rwxrwx--x' (771)
Processing (161 of 175): com.android.deskclock...
Changing permissions for: /data/data/com.android.deskclock from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Changing permissions for: /data/data/com.android.deskclock/databases/alarms.db-wal from 'rw-r--r--' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.android.deskclock/databases/alarms.db-shm from 'rw-r--r--' to 'rw-rw----' (660)
Processing (162 of 175): com.android.spare_parts...
Changing permissions for: /data/data/com.android.spare_parts from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (163 of 175): com.koushikdutta.rommanager.license...
Changing user ownership for: /data/app/com.koushikdutta.rommanager.license.apk from '0' to '1000'
Changing group ownership for: /data/app/com.koushikdutta.rommanager.license.apk from '0' to '1000'
Changing permissions for: /data/app/com.koushikdutta.rommanager.license.apk from 'rw-rw-rw-' to 'rw-r--r--' (644)
Changing permissions for: /data/data/com.koushikdutta.rommanager.license from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (164 of 175): ales.veluscek.sdtools...
Changing user ownership for: /data/app/ales.veluscek.sdtools.apk from '0' to '1000'
Changing group ownership for: /data/app/ales.veluscek.sdtools.apk from '0' to '1000'
Changing permissions for: /data/app/ales.veluscek.sdtools.apk from 'rw-rw-rw-' to 'rw-r--r--' (644)
Changing permissions for: /data/data/ales.veluscek.sdtools from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (165 of 175): com.google.android.gsf...
Changing permissions for: /data/data/com.google.android.gsf from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Changing permissions for: /data/data/com.google.android.gsf/app_sslcache/android.clients.google.com.443 from 'rw-------' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.google.android.gsf/app_sslcache/mtalk.google.com.5228 from 'rw-------' to 'rwxrwx--x' (771)
Changing permissions for: /data/data/com.google.android.gsf/databases/subscribedfeeds.db-wal from 'rw-r--r--' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.google.android.gsf/databases/subscribedfeeds.db-shm from 'rw-r--r--' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.google.android.gsf/databases/talk.db-wal from 'rw-r--r--' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.google.android.gsf/databases/talk.db-shm from 'rw-r--r--' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.google.android.gsf/databases/gservices.db-wal from 'rw-r--r--' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.google.android.gsf/databases/googlesettings.db-wal from 'rw-r--r--' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.google.android.gsf/databases/gservices.db-shm from 'rw-r--r--' to 'rw-rw----' (660)
Changing permissions for: /data/data/com.google.android.gsf/databases/googlesettings.db-shm from 'rw-r--r--' to 'rw-rw----' (660)
Processing (166 of 175): com.qik.android...
Changing permissions for: /data/data/com.qik.android from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (167 of 175): com.bytesequencing.spades_ads...
Changing permissions for: /data/data/com.bytesequencing.spades_ads from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (168 of 175): pl.skifo.radio...
Changing user ownership for: /data/app/pl.skifo.radio.apk from '0' to '1000'
Changing group ownership for: /data/app/pl.skifo.radio.apk from '0' to '1000'
Changing permissions for: /data/app/pl.skifo.radio.apk from 'rw-rw-rw-' to 'rw-r--r--' (644)
Changing permissions for: /data/data/pl.skifo.radio from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (169 of 175): nextapp.systempanel.r1...
Changing user ownership for: /data/app/nextapp.systempanel.r1.apk from '0' to '1000'
Changing group ownership for: /data/app/nextapp.systempanel.r1.apk from '0' to '1000'
Changing permissions for: /data/app/nextapp.systempanel.r1.apk from 'rw-rw-rw-' to 'rw-r--r--' (644)
Changing permissions for: /data/data/nextapp.systempanel.r1 from 'rwxrwxrwx' to 'rwxr-xr-x' (755)
Changing user ownership for: /data/data/nextapp.systempanel.r1 from '0' to '10146'
Changing group ownership for: /data/data/nextapp.systempanel.r1 from '0' to '10146'
Changing permissions for: /data/data/nextapp.systempanel.r1/shared_prefs from 'rwxrwxrwx' to 'rwxrwx--x' (771)
Changing user ownership for: /data/data/nextapp.systempanel.r1/shared_prefs from '0' to '10146'
Changing group ownership for: /data/data/nextapp.systempanel.r1/shared_prefs from '0' to '10146'
Changing permissions for: /data/data/nextapp.systempanel.r1/shared_prefs/nextapp.systempanel.r1_preferences.xml from 'rw-rw-rw-' to 'rw-rw----' (660)
Changing user ownership for: /data/data/nextapp.systempanel.r1/shared_prefs/nextapp.systempanel.r1_preferences.xml from '0' to '10146'
Changing group ownership for: /data/data/nextapp.systempanel.r1/shared_prefs/nextapp.systempanel.r1_preferences.xml from '0' to '10146'
Changing permissions for: /data/data/nextapp.systempanel.r1/databases from 'rwxrwxrwx' to 'rwxrwx--x' (771)
Changing user ownership for: /data/data/nextapp.systempanel.r1/databases from '0' to '10146'
Changing group ownership for: /data/data/nextapp.systempanel.r1/databases from '0' to '10146'
Changing permissions for: /data/data/nextapp.systempanel.r1/databases/SystemRecord.db from 'rw-rw-rw-' to 'rw-rw----' (660)
Changing user ownership for: /data/data/nextapp.systempanel.r1/databases/SystemRecord.db from '0' to '10146'
Changing group ownership for: /data/data/nextapp.systempanel.r1/databases/SystemRecord.db from '0' to '10146'
Processing (170 of 175): com.google.android.apps.androidify...
Changing permissions for: /data/data/com.google.android.apps.androidify from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (171 of 175): com.leadapps.android.radio...
Changing user ownership for: /data/app-private/com.leadapps.android.radio.apk from '0' to '1000'
Changing group ownership for: /data/app-private/com.leadapps.android.radio.apk from '0' to '10102'
Changing permissions for: /data/app-private/com.leadapps.android.radio.apk from 'rw-rw-rw-' to 'rw-r-----' (640)
Changing permissions for: /data/data/com.leadapps.android.radio from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (172 of 175): com.google.android.syncadapters.contacts...
Changing permissions for: /data/data/com.google.android.syncadapters.contacts from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (173 of 175): com.google.android.backup...
Changing permissions for: /data/data/com.google.android.backup from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Changing permissions for: /data/data/com.google.android.backup/app_sslcache/android.clients.google.com.443 from 'rw-------' to 'rwxrwx--x' (771)
Processing (174 of 175): com.rerware.android.MyBackupPro...
Changing permissions for: /data/data/com.rerware.android.MyBackupPro from 'rwxr-x--x' to 'rwxr-xr-x' (755)
Processing (175 of 175): com.adobe.psmobile...
Changing permissions for: /data/data/com.adobe.psmobile from 'rwxr-x--x' to 'rwxr-xr-x' (755)
/data/data/com.koushikdutta.rommanager/files/fix_permissions 2.04 ended at 03-05-2011 11:36:09 (Runtime:5m30s)
Interesting. Honestly, I wouldn't have thought to try that. I highly recommend you update your OP with clear steps of what you did (i.e. 1) get broken Evo 2) nandroid backup broken phone, etc. etc.). I guess this is ultimately the same thing we were talking about with you trying with my keys, but without me losing 4g as a result :). That's really cool that we know this works.
:) done and done!! :cool:
So, I see that you have a different wimax version than you did in your other screenshot after the fix. Did you update it? It's still not the latest (not that it matters, apparently).
i flashed an older one to see if it would help with reception, but of course it didnt!
