FisheyLP
WOW THANK YOU!!I rooted over a week ago and ever since have been receiving an error when i try to download about 35% of apps from the play store. Video attached. Any ideas?
Thanks in advance
SOLVED SOLVED SOLVED
If this happens to you after rooting, go to the play store and follow these steps:
1. Search for Link2SD. You MUST DOWNLOAD A VERSION THAT IS AT 2.3 OR LOWER. LINK FOR 2.3 IS BELOW.
2. Install it
3. Open it, if prompted, grant it super user access through superSU
4. Tap menu, then settings
5. Scroll down to Install Location
6. By default it is set to external, change it to automatic.
7. Exit Link2SD and try downloading an app that was not working before, again, it will work now
Link2sd v2.3 download: http://www.sendspace.com/file/bh4c89
so glad this is finally fixed. Thanks for the help guys
NOTE:
The Motion is currently on firmware version F. For some reason, every time they release a new firmware, at least one app still will not update or install. For firmware E it was MixZing and for firmware F it was MX Player. Not sure why this is, if I find a workaround I will add it to this OP.
I registered here just to give your post a likeI formatted my sd card, internal storage, tried to repair corrupted data partition and even completely wiped everything and reinstalled a new rom. The problem kept appearing, but with Link2sd it is finally working now
Strange that Link2sd could be installed successfully but other apps couldn't before, but I don't care ^^
