So i should root the phone with odin, and after i should instal cyanogenmod?
I am looking to those forums with root. I am so confused, idk what to do..what to download. Can you guys help me? I will give u all the infos about my phone.
dont update your phone you will get knox bootloader which will render your warranty useless
Everything we are talking about will, and my warranty with knox tripped was just fine.. Besides that thats not why you hear people talking about knox.
OP is asking about rooting, so clearly he is not to concerned about his warrenty. Even if we get the ability to set the flag back to zero, that does not magically mean you did not void your warranty. Even with flags tripped on your phone, they still might honor your warranty. As I said before, flashing/rooting will void your warranty regardless of knox.has yet to be cracked yet by devs to reset the flash counter therefor voiding warranty
Knox being cracked is not that issue, that sounds like fraud. If you are worried about your warranty you should not be rooting period. Having a tripped knox flag does not mean your warranty will not be honored.until Knox is cracked that's the issue.
Why is that? What's so different about it?Rooting my S3 was the best thing I did with the phone
