subarustiman
I'm new here and was looking around the forum. I realize there are some good stickies and I have gathered some good info, but also I have some questions that I still need answering before rooting my X2 that is on 2.3.4.
My ultimate goal is that I want to root so I can freeze/delete bloatware and then SBF back to 2.3.4 or go back to the newest stock Gingerbread. I am aware that OTA updates usually wipe most root access, but:
1)if I want to get future OTA's, like 2.3.5, do I need to SBF back to 2.3.4?
2)Are SBF/unrooting the same process?
3) If I root, freeze/delete bloatware, then unroot/SBF back to 2.3.4, are my changes permanent; will that bloatware continue to be blocked or do I have be rooted in order to stop those crappy apps from taking up system resources?
4) Once I'm back to stock hopefully, would I use something like RootChecker to verify it's all stock?
5) I'm pretty knowledgeable about tech, so I'm not really used to being new with stuff like this. When I do something like this, I always make sure that I have all the info/steps of the process at hand. I was planning on using Pete's OneClick for rooting. That being said, what are the chances that my phone would brick or become unusable?
6) Is there an official 2.3.4 SBF or are we all currently limited to the "leaked" version. Basically if I need to recover, I want to make sure that I can go back to the original. Is that something that would help by doing a back-up?
