Yes, it has hsdpa, no Touchwiz isn't included, the GPS is iffy, depending on what you've done so far (I think it's pretty good for a Captivate, but that doesn't mean much). You can use the video link in my signature for good instructions.I'm looking at flashing Serendipity to my rooted stock 2.1.1 Captivate. Does it have hsdpa & hsupa ? Is touchwiz also included ? Will my GPS improve ? Are there videos for installation from start to finish around ?
Thanks
Yes, it's the same process. As for speed, it's fast enough for me....I've never bothered with speed tests. Maybe I will just for kicks, what should I use?
. Seemed laggy even with OCLF. So i went ahead and installed Serendipity. Followed the instructions from the videos (thanks reinbeau) and damn is it FAST. No lag, clean and best of all my speedtest jumped to 3.40Mbps down and 1.29Mbps up. Never, ever did i get this speed with the stock rom, lol. If your on the fence about flashing a rom, DO IT
