Help Some questions
I have been using fascinate for about 5 days now, had some questions.
1) Right now I downloaded ADW Launcher which I like a lot, but I was curious is there anyway to use some of the widgets from Samsung with this launcher? Specifically Facebook and the clock?
2) I understand you are not suppose to kill apps in task manager unless it stops responding, but I was curious about using the web browser, if that is on in background will that kill battery because of it using 3G constantly? What is proper way to close.
Thanks
Thanks
1. samsung widgets will only work with touchwiz...stinks but thats the way it is :o
2. you dont have to kill the browser....just hit home key....3g data goes dormnant when not being used after awhile to reduce battery drain...unless you are in a bad 3g area and the phone is searching for data service :)
Oh I am having one more issues that is driving me crazy.
The sensitivity when moving the SF in that it switches from orientation to landscape too easily and then it gets stuck and wont move back to orientation. I know I can switch it off but like to have that option of changing it.
Is that common? I wonder if there is a manual way of doing it without having to go into settings all the time so i don't have to turn it off permanently?
