Help some1 plizz help me new android phone
i just got the optimus v phone from virgin mobile
i have downloaded apps but they do not show in ma main screen where the camara nd all those apps are...wat can i do ?? HELPPPP!:(:confused:
To put apps on your main screen, you have to create a shortcut. First press and hold on your main screen. In the menu the pops up, select shortcut. Then select the application you want and it will be on your main screen.
You have to open the "app drawer". Either press the little icon with all the squares or select the Menu button, then select Applications.
