Root Somebody plzzzz help! Can't root!
flboy91
I've been trying for four hours with no success.... Can't get past all the. Folders stuff and cmd prompt.... Help plz
It's much more daunting reading about it than actually doing it. Just follow the tutorial and copy /paste the commands directly into your command prompt.
I downloadedit but wen I go to the command prompt it I can't get it to except adv reboot bootloader... It tells me it doesnt recognize command
try typing in "adb usb" without the quotes and run that. that fixed my issue and i feel it should probably be added to the rooting sticky if there is a troubleshooting section.
Thanx bro ill try wen I get off and update
The msg I'm getting after typing "adb USB" or "adb reboot bootloader" am I doing something wrong?? NEED HELP
are you absolutely certain that adb.exe is in that folder? double check that. that error means it can't find the executable in that directory.
take a screenshot of what's in your C:\sdk-tools folder. btw alt+printscreen takes a screenshot of a window so you dont have to keep taking pics with your phone or camera
uhm, looking at that picture... i think you have a folder called sdk-tools inside another folder called sdk-tools.
take everything from that folder, and put it in the main folder.
it should be c:/sdk-tools not c:/sdk-tools/sdk-tools
that should do it. i didn't even catch that...2 AM over here
uhm, looking at that picture... I think you have a folder called sdk-tools inside another folder called sdk-tools.
Take everything from that folder, and put it in the main folder.
It should be c:/sdk-tools not c:/sdk-tools/sdk-tools
thanx! Ima try it now!
did you put in "fastboot oem get_identifier_token"? you need that to unlock the bootloader, sounds like thats what step you're on
ok i did tht but got a FAIL but when i took the underscores out i got the INFO #S... I NEVER GOT THT BOOTLOADER PART ON THE PIC THATS POSTED ONLY THE INFO PIC
Check your folder at the address bar I had to use CD c:/sdk-tools/sdk-tools/sdk-tools. And another was CD c:/sdk-tools/folder/sdk-tools. But also you can go to the sdk folder go all the way in hold shift and right click and the choose open command window. Try that it gets annoying I know
i think i did evo 3d and it worked for me, but i would listen to the Harmonia dev tho...
It will probably work on either to be honest. I used other, but I am also sure some people used Evo 3d.
Any one of you could make any version of Harmonia. ;)
