Root Someone help me reinstall swype PLEASE!
I tried to install the new beta swype thats been out for while now and deleted the old (preinstalled) swype to get the new one. I installed the new beta swype but it wont work. And I cant reinstall the (preinstalled swype) for some reason. I just want the original swype keyboard back. I dont care about anything else at this point just want my keyboard back with out having to factory reset -___-
Factory reset will not bring it back if its already gone. You cant install swype like a normal app.
Also sense your in the All Thing Root section im hoping your Rooted.. so install Titanium Backup then make backups of your system + Data then factory reset/Reinstall any Roms, Kernels, and other zips... (just to be safe)
Then install Titanium backup and restore your lost data this time don't remove swype... :P
FYI, link to official sources (developer website, Google Play Store, Amazon, etc) instead of sites that host downloads for pirated apps.
Here is the link from their official website. Swype | How Do I Get Swype?
Note, it will not work if Swype came pre-installed on your phone. You can email the dev to ask for help in that situation.
Thank you for your understanding. :)
