Someone please help!!!
lady1k3
Okay.. so, i tried to install a rom onto my Lg Lucid.. turned out bad because i forgot to back up. Couldnt get passed LG logo, just went to black screen. Tried the delooper just now, that lead me to the same thing except now, I cannot get back into CWM. It shows the little android guy with the box, has a loading bar that finishes and then it just reboots my phone. what do i do now.. I just want my phone back to normal "/
First,there is no ROM for the Lucid yet.Try using the LG Tool.You can download it at LG.com.You can basically restore your phone back to stock and it will remove your root.Good luck.PM me if you need any help.
