Help someone please help
jstoner
Ok I'm rooted and their was an updated to f and it downloaded it shut my phone off and went to install but an error stopped it and then it rebooted and says I'm rooted not longer can update but now I do not have the internet called metro pcs they they tried and no luck
So if their is a way to fix it plz let me know steps still learning and don't understand a lot of things thanks. Also did a hard reset and no luck that way was going to restore it back like the unbricking but I can understand how to do it I have the d fermwere and I got the flash thing but it says it's empty and the fermwere I don't now what to use to open it on my pc thanks
I had the same problem i tryed updating and it did and said the samething but my phone just turned off and turned on like nothing happen. Try to turn it off for a bit then turn it back on.
Oh... I been there done that.... about a month ago when "E" came out.
Sorry for your troubles.
Then "F" came out. No thanks!
Then, Metro sent a txt to me saying I could have tether back for $10 a month!
Ya so un rooted and updated to f and now cant play black opps 2 on the xbox connects but wont load matches? Crazy bout to flash and root bet it will work lol
