Accessories Someone with a Seidio Holster -- Question
mx7
Can the phone be attached with the device facing the outside? If so, how snug is the fit?
This applies to holsters that are made to use Without the Seidio case.
Much appreciated
Much appreciated
Negative, it only snaps into place with the phone facing inwards (bottom ports get in the way facing outwards). I returned it for this reason. It was a nice holster, but i'd bump it too much to have a holster with the phone completely exposed that way. I thought i'd be able to mount it in the car with the phone facing outwards but it wouldn't fit that way at all for me, nor would it fit with the minimal ebay style case on it. Only thing it could be used for was a bare phone (no case at all) facing inwards.
I'm using it for a similar purpose. Did you end up creating a mount for it?
Nah, i'm trying to hold out till HTC makes a car dock (IF HTC makes a car dock) or maybe modify a generic mount to my liking if i get too impatient. Currently, i'm using an FM transmitter and power inverter in my truck and just setting the phone on the center console or cupholder :( I'd rather use a window mount if i can find one that will fit and doesn't look cheap, but i haven't found one yet.
