Help Somthing is turning on mobile data
SeaMitsos
I close mobile data (from the settings or even from the power button with data network mode).
Somehow after some time is on again.
Probably because of an application ?. Is that a bug ? how a can an application take that control ? , how can i find which application is that ??
The charges for the mobile getting bigger an bigger !!!
If the device is changing its setting by its self then that can most certainly be a software issue. What might be actually causing the issue though can be a few things. Your right about apps, the #1 thing to consider is an app causing problems. But it could be a bug or glitch too.
Do this
You could look what apps use data shortly after data is on again, using an app like 3G Watchdog.
And then uninstall to most suspicious of these apps and watch the issue for a while and so on.
Harry
Thank you all for your help.
I will postpone backup and reset for some days and i will try to specify the problem with My data manager.
I'm using 3g watchdog pro. Many applications have use the network today and all of them have permission for network communication.
You might try this permissions way.
The app Pockets Permissions shows all permission of your app in an overview.
After opening the app choose 'Permissions' and then 'Change Network State'. It'll show you all of your app that have this permission.
BTW, the dev of this free app is a mod in this forum :)
Harry
Where can i find that "Pocket Permission" app ??
Harry
