Help Sony Erricson won't turn back on!
YeahDaryl
Well, simply, it won't turn back on. Whenever I was in the lock screen it would say it was charging, then I would slide down from the top and it would say it was discharging. So, thinking it was a small bug I turned off my phone and tried to turn it back on later. It doesn't turn back on. I've had this problem once before, but it turned on in just a few minutes but now it won't. When I connect it to the charger, it doesn't connect properly like it needs to be plugged in at a certain angle for it to actually start charging. This problem also happened before as well, but as soon as the phone itself turned on it would charge perfectly.
If there's any help or suggestions I could get from here, it would be greatly appreciated.
Thanks!
