Sony liveview? Don't bother
mcnob
It's not compatible with the desire hd. The music controls don't work with the handset at all, the phone gets hot and slows down from prolonged use and it loses connection periodically...sometimes locks up completely.
I hope they fix the issues coss I bought one but why would they? Its not one of their phones.
So there you have it, don't believe the hype. It's NOT compatible with all android phones as advertised.
Have same problem with desire, pairs up ok, works brilliantly, then wont pair, or just freezes, after a bit of fiddling, it will work then stops again, cant clear sms from liveview,
lent it to my mate with a galaxy, if it works he can buy mine,
nice idea but flawed in its compatabily.
