Sony Xperia z ultra pen function doesn't work
edward90
Had this phablet for 2 days love it so far..but I can't get the pen function to work.. Does anyone know a fix?
It might depend on the pen. I've read it only works on pens that are all metal and not plastic disposable ones. Some reviews said this was hit or miss at times.
Don't put hope on the gimmicks feature of any input support.
The pen or pencil input is working but not as smooth as Samsung S-Pen.
I think Sony put this feature is not a pros but instead cons, It make the screen too sensitive to nearly get touch by anything.
You try drop few water on top the screen, then you will notice water drop is helping you opening up apps for you. :P
