Help "Sorry, process null not responding. wait or retry?"
JustinHEMI
What the heck does that message mean and why do I get it when using the stock browser on this forum only so far?
Thanks
Justin
It probably has something to do with this website and its advertising. There's probably some code that's initiating some action and generating the error. Do you have popups blocked? Do you have "Enable Mobile View" turned off? I'm betting it's a combination of settings and this website's "lovely" popups/advertising that's generating that error. After you clear the error you can still view the website right?
It has happened to me here before. This site is loaded with ads and useless crap. Usually if I hit wait the server will respond, but sometimes not. And I have had it happen on more than one occasion using wifi.
Between vBulletin, the skin and the rest of the junk, it's a wonder you don't get more errors. Sometimes when browsing on my home comp, this site takes a while to load.
Yeah I think you're right. I have mobile view turned off and popup blocker turned on so it seems to be an issue with the popups here and a combination of settings. I won't worry about it then. :)
Thanks X thanks Tx!
Thanks X!
After turning on "Mobile View" do the errors go away? Might be something that the site admins would like to know as I'm sure they'd rather have a website that works happily with an Android phone's browser.
Sorry I totally forgot to say thank you..., in all honesty, I simply saw the X and assumed the same person responded twice. :P
Anyway, I haven't done that yet but I will later and report back.
Justin
