Help Sort Pictures
maf84
Is there a way to prepare you pictures so they will be sorted by file name in the gallery? After copying the pictures to the SD card they are in some jumbled order. I have stripped all meta data from the files but still they don't sort by filename.
Thanks
Thanks
I would just use a different gallery app, like "quickpic", and set it to sort by name in the options. Quickpic is faster and has a lot more options than the stock app.
