DrJonathan
Hello all. I've a couple of questions or so that might show my ignorance, but then I've only had this handset - HTC Desire - for one week exactly. I'm having a seemingly illogical problem with my internal storage: I have a 16G micro SD card installed, and wherever possible store any apps and downloads on it. Although I no longer store apps on my internal storage, when I downloaded an app to the SD card earlier today, I got the low space warning icon in the menu-bar, telling me that my internal storage is running out of space. Is this something normal that It simply don't understand, as I've not stored anything internally to warrant the icon, or some sort of problem that shouldn't happen? In either case, what, if anything would you suggest I do? Secondly, when setting up the phone, I chose to have the key click sound turned on when typing. This worked fine up until today, when it suddenly disappeared. I now cannot, for the life of me remember how and where I would turn of back on again. Why would it suddenly disappear? On pc's I know that conflicts can arise between applications and programs, is it the same with smartphones, and if so, how would I go about finding the source of the issue? I hope I'be made my questions clear enough. I would appreciate any and all advice and suggestions. In advance, thank you for any help you might offer. J.
