Help Sound Recording App. Help
sandy43
Reference the sound recording app on my Commando. Is their a trick to making it work properly. It records, but can't play back or find it when saved. Explain the fundamentals of how this thing works. Great tool for someone who has a remembering problem. All help is truly appreciated. Thanks
Hi all... I also recorded some test messages on my new Commando phone. Couldn't figure out how to play back. So, I went to the Verizon store and they couldn't either. Is there an answer to being able to access our audio notes?
Thanks for any help.
I thank youall for any help.
I have the same phone and same problem. Go to bottom left button that brings up add manage apps wallpaper etc. Hit add. Add wigits voice memo wigit and you sould figure it out
JD
bottom left button---add---add wigits
JD
Thank you so much. I did find my recordings through Documents to Go, but the method you stated for the widget is much more simple and quicker.
