My quest is to have M2/MegaGrip combo
I have an additional T-Tab for my MegaGrip which uses a screw instead of ball joint connector. I want to figure out if I can connect MegaGrip with a screw to M2's swivel head. Would be ideal since I prefer less-intrusive MegaGrip versus metal disc attachments to the back of my DX/case. But I will not know for sure until I get M2. BTW from my other post, you can still get M2 for $4.99 with "woot" discount from wiredforless.
its 20 from akrons website
Will post pics later.Got my M2 yesterday, installed and tested it todayWill post pics later.
By far this is the cleanest and less bulky DX mounting setup I have seen/tested so far, and its also one of the cheapest one. As long as you follow instructions correctly and wipe and wait a few minutes for surface to dry out before applying anchor disk to the phone and mounting base to the car - it should stick dead on. I have Luxmo TPU soft gel case and there is no problem for a disk to stick and stay on. I also prefer it over the magnet, such as XWay, so it will not pull on the case when you remove the phone even with twisting. This one is simple, dock the phone and twist it to lock it. Remove the same way, don't need to pull anything, just rotate the phone to unhook it and to pull it out.
Regarding taking mount out of the car and damaging your dash, well its a VERY STRONG 3M double sided tape piece. I placed mine on the plastic edge of my car audio/climate control cluster, and I'm pretty sure it will leave a mark once removed. If you are placing it on the dashboard exposed to the sun/heat, the leftover after removal could be messier. But it would be the same if you are placing one of those dashboard discs for suction cup mount. Vent mount is the cleanest attachment, but in a lot of cars where vent rib rotates horizontally it will not work.
As much as being a huge fanboy of Arkon because it doesn
