OK , heres my situation ...Im sure its prob. been ask here before but I could not find it using the search ( eyes started getting crossed from all the threads i read )
Ive had my Hero for about 9 months , havent had any battery issues to say ( read the sticky about saving battery life )
heres my problem , Some days battery will last all day with , as I say , avg use .( Text , check e mail 3-4 times , FB , handful of calls , Music ) AND then after 4-6 days its goes to dropping 10% in the first 20 minutesin the morning and then needing a charge by noon .
VERY minimal APPS on Phone . Using Spare parts , during good battery usage , The top user is the ANdroid system and its very low.
NOW during the bad times Spare parts show the Android Sytem still on top but its up to 100% of the time
I can go into manage Applications and start forcing things close and it helps for awhile , but they start up again....... and then sometime out of the blue , it goes back to normal . Its driving me nuts !!
any suggestion on what to check , im scratching my head
