Hi All
I am a newbie to this forum and also to the new HTC Hero H3700.
Mine arrived yesterday and straight out of the box I had the option on power-up to use the SPB Shell 3D and set it as default.
I did this and found it just fantastic so proceeded to set up my mail, wireless, weather settings etc etc.
At some stage while setting up all my personal preferences a launcher window appeared, giving me only 2 options to continue. My SPB Shell 3D had gone from the options and I was only given the choice of two shells.
I found I could go no further unless I selected one of these launchers shells, and so selected Launcher +
However as you would expect my nice 3D shell was never to be able to activated again. Even though it still showed that it was actually on the phone, I could not get to it, to start it up again.
After many hours of searching it would appear that once the process happens, the 3D launcher is disabled and can not longer be selected in the phone.
To restore the 3D launcher back I have to restore the phone to its factory defaults and loose all my personal settings each time.
I have looked at all the other shells but they are totally flat when compaired to the easy of use with the 3D version and it looks fantasic.
I would dearly like to have this shell as the default however without rooting the phone and going into the bowls to find out what is happening, is a little beyond my capabilities, right now plus I have only owned this phone for 24 hours!
I would appreciate any help that you all may have with this problem.
Everything else appears to be functioning correctly
thanks in advance
Tubby1957
thanks in advance
Tubby1957
