Help Speaker Cleaning
Bossman74
Did you guys notice how the speaker on the Milestone/Droid gets dirty, it's like a magnet for dust and lint, and once it's in there, it won't come out...
I just found a little trick to clean it out:
1- Just grab a little amout of "fun-tak" or any other sticky putty.
2- Push it into the speaker hole, and the dust will come out with it when you remove it.
3- Rince and repeat ;)
I was so glad to finally get it clean, that I had to share it.:D
I've noticed, and I've had mine since friday. Android is just so much more rewarding on better hardware (Coming from a dream. )
I miss root + Custom roms, sure, but the build on telus is fantastic anyway. Only difference is PDANet instead of wired tether built in.
