Help speaker mode auto in calls
bilbo_c
Model: htc desire
Network: Orange
Task killer: none
Android version: 2.2
Hi I've read the other posts about this and none have helped so far. Recently when I make a call or receive one, my desire goes into speaker mode automatically.
I'm not in car mode or anything like that. I am rooted but have never flashed a different rom. Please help! This is so so annoying.
Thank you,
Thanks to phantom848, just spotted something on that thread i previously missed!
Thank both of you so much!
Update.
Just chatting to a fella in work here an his is doing the same.
So used the car setting to turn of car mode but his loudspeaker was playing up.
So deleted his market update.....
Used astro file manager to open memory.
Select SDCARD..
Then select android
then select data
Now clear everything out of the three folders
One is called com.android ............ an the other two
Are called com.Google......
These are like a download memory cache files.
Now go back to SDCARD menu
And open the file called download.
In there there was a new file that had appeared
But it wasn't pdf,lpeg etc
It was an unknown format ,deleted that.
That was it, loudspeaker back to normal
And no car mode.so that's twice its worked now
