Help Specific volume needs?
Llama, Tasker, and AutomateIt will let you setup your sound profiles based on conditions. Check them out and decide which app will work best for you.
Thanks for the recommendations. AutomateIt seems intuitive and it's my favorite so far. I set it up to enable wifi at home - that worked for a day, but now it doesn't and I can't figure out why. I didn't try Tasker.
You can try and take a look at the Location Trigger user guide at the following link:
Android Muzikant: AutomateIt Location Trigger - Tips and Tricks
Or you can try and use the Cell Id Trigger as described on the following link:
Android Muzikant: AutomateIt - Cell Id Trigger Guide
