thebryceee Android Expert Jun 3, 2012 #2 It's the same port as the micro usb I believe. You need a conversion cord or something?
E Etegral Newbie Jun 3, 2012 #3 Yup, it goes through the micro USB port. It does this using MHL, so unless you have an MHL-enabled TV, you need an adapter that converts it to HDMI. I never used the HDMI port on my Triumph, but if you actually plan to output to a TV a lot, the adapter might be worth it.
E EdAndInn Well-Known Member Jun 3, 2012 #4 I saw an add on Amazon.com as: OEM HTC MHL HDMI Adapter for HTC Sensation / HTC EVO 3D Amazon.com: OEM HTC MHL HDMI Adapter for HTC Sensation / HTC EVO 3D: Cell Phones & Accessories Plus, you will need HDMI cable too. There are other OEM products which are cheaper. Search - HTC EVO 3D HDMI Adapter
