Speed Dial Does Not Work
I have set up speed dials, however it only works intermittently. By this I mean half the time I hold the speed dial number it works and the other half of the it says "No speed dial assigned" although they are listed.
I know this isn't exactly what you want, but I do my speed dials like this. Long press anywhere on a blank space on your home screen. Select the Widgets option. Then look for the "Direct Dial" widget. When you select it, you can select a contact and their number you wish to be used for contact in case they have more than one number. I then put all the contacts I create into a folder on my main home screen. Much faster than accessing the dialer all the time in my opinion.
Hope that helps.
