Help Speed Dial
fekish
Hi,
in the end, is there an application that really is speed dial for Android, like the traditional way, and that it doesn't have any lag in it? And which would have larger contact icons in high quality photos?
I am using QuickDial but i am frustrated by the time it has to load every time i click it, and thus is not as "quick" as it says...
Have you tried adding direct dial shortcuts to one of your screens? That works perfectly for me.
Yeap thanks.
I had this in the past, but i miss larger contact photos of other programs thus i was looking for something with better photo quality.
QuickDial is nice, but it always takes a bit to load.
Yeap thanks.
People Widge is a widget and does not need to load, stays ready all the time.
I do not use any of these because I use LauncherPro with the scrollable dock. I disabled loop scrolling and thus can scroll to the right or left and have 5 shortcuts on each side. I added 5 contacts on each side and am very happy with this solution.
