AaronEmoBoi
Member
IF YOU HAVE BOOST MARQUEE DO NOT USE THE SHORTCUT WAY ENTER ALL THE LINES OF CODE MANUALLY
Okay guys so i stumbled onto a speed tweak technique and well it works i tried it and used it and i do see a noticeable difference in the marquee now im going to explain how to do it
If you have a sprint marquee and would like to have a shortcut to do this download the Attached build.prop and backup your and replace it with mine Boost cannot do the shortcut method since the Build.prop contains carrier info needed for the phone so if you run Boost's Marquee you have to type it all out sorry guys
Each one of these lines of code needs to be on a different line when your in the text editor it will change the
key into a enter key to give a new line so yeah
you need a File Explorer with root privileges perferably Root Exporer (attached below )
1. go to /system directory (open Root E and go to system folder )
2. mount R/W
3. Find in the system folder build.prop , its a file then long press it and click open in text editor
then you will have a long list of lines of code dont erase anything or add anything other than what i tell you too
Force Launcher into memory:
ro.HOME_APP_ADJ=1
Raise JPEG quality:
ro.media.enc.jpeg.quality=100
VM Heapsize; higher the RAM, higher the hp can be:
dalvik.vm.heapsize=48m
Render UI with GPU:
debug.sf.hw=1
Decrease dialing out delay:
ro.telephony.call_ring.delay=0
Help Scrolling Responsiveness:
windowsmgr.max_events_per_sec=150
Save Battery ( three of them each in a different line )
wifi.supplicant_scan_interval=180
pm.sleep_mode=1
ro.ril.disable.power.collapse=0
Increase overall touch responsiveness:
debug.performance.tuning=1
video.accelerate.hw=1
Raise Photo and video capturing quality:
ro.media.dec.jpeg.memcap=8000000
ro.media.enc.hprof.vid.bps=8000000
Fix some application problems:
ro.kernel.android.checkjni=0
Disable boot animation for faster start up (optinal i havent tested it)
debug.sf.nobootanimation=1
so yeah type these into your build.prop then press menu button then save changes and it will make a auto backup of your current build.prop
build.prop
key into a enter key to give a new line so yeahyou need a File Explorer with root privileges perferably Root Exporer (attached below )
2. mount R/W
ro.HOME_APP_ADJ=1
Raise JPEG quality:
Render UI with GPU:
debug.sf.hw=1
pm.sleep_mode=1
build.prop
